Originally Posted by
Jackal55
Well, I ripped a 3rd BR and got the folders all setup and MB will now recognize each BR movie but won't play them. Told me that the path didn't exist. I have to get them to play through MPC-HC correctly now. I chose it as the external player in the MB config box so I no longer get the error message. MPC opens but the movie won't play automatically. I'll go over the info in the beginning of the thread and get that all setup next.
You can`t play BR folders with PDVD9, i told you. You have to got with ISO images or mkv rips. My guide uses TMT3 that can play BR folders (that`s the only reason a i recomended it or PDVD9, that and it doesn`t have that stupid MooovieLive or whatever it`s called). MPC-HC is used for mkv/m2ts/ts playback in my guide
Jackal55
PDVD won't play the BR folders but that's ok. I'll just take the time to setup MPC-HC later. I would just play the streams in 7MC but I like having the meta info and would like to use MB. I'll get it together. The TV season is just ending so I have all summer to get it right.
You can do (play just the stream file), that, just respect the file/folder naming convetion and you will still get meta info in MB, no matter what extension.
for ex :
D:\\Movies\\Dark Knight (2008)\\Dark Knight (2008).m2ts
Media Browser doesn`t care what type of container you put your movies into, it just wants the correct file/folder name. Actually, the folder name, the file name doesn`t count i think.
Media Browser 2.2.4 (Cronos) which will be released soon (in a couple of days) will ignore "_" between words so you don`t even have to rename them.
But personally i would go for ripping to mkv since you get chapters that way
Offtopic :
bryansj,
dbone, do you guys know who the moderator/moderators of this section is/are? I`m going to try to apply for a sticky but have no clue who to contact.
