AVS › AVS Forum › Video Components › Home Theater Computers › Windows 7 Media Center : Setup Guide, Knowledge Base & Support
Featured Stories
Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 53
- GreenEyez
- Trader Feedback: 0
- offline
- 2,258 Posts. Joined 1/2010
- Thumbs Up: 16
- Select All Posts By This User
post #1563 of 4573
9/4/10 at 7:10am
- MiBz
- offline
- 1,093 Posts. Joined 5/2005
- Thumbs Up: 10
Originally Posted by uolsona
Thanks Mibz,
It cost me $125 to confirm this was the problem but I needed another 2TB drive for the NAS anyway. Everything works great with the drive in the HTPC. Just need to figure out why the network is giving it problems when storing the files on the NAS.
Thanks Again!
Thanks Mibz,
Thanks Again!
You're welcome. In most cases, it's better to rip and remux locally. Writing and deleting many files causes unnecessary fragmentation on your NAS storage. By doing this locally, windows can defrag the drive. When done store the completed movie on the NAS. Network speed will also slow things down considerably when you're demuxing and remuxing over the network.
post #1564 of 4573
9/4/10 at 8:24am
- trooper11
- offline
- 366 Posts. Joined 9/2004
- Thumbs Up: 11
I wanted to say thanks for this great guide, it has helped me alot in getting my new htpc build going.
I am having some difficulty with the customization side of things though and was wondering if anyone had any suggestions. I am running Windows 7 HP 64bit and followed the guide here for my setup.
I got media center studio and have been playing around with adjusting the 7mc start menu. The problem is that ive had very limited luck in my changes actually being applied to 7mc. Now maybe this is just a limitation of the studio currently, but some changes either are ignored or MC becomes unstable and wont launch at all.
Maybe someone can suggest a better what of setting things up, so ill list the scenario im after:
1. I want to modify the Movie section by disabling the standard entry points (library, search, play dvd) and add in new entry points (MB link to Movies and TMT3 link to playback dvds or blurays). So I used MCS and unchecked the old links and then added the new entry points i wanted. I saved it and then launched 7MC. Nothing was different, my points werent added and the standard ones were still showing up.
2. I want to seperate the Pictures and Videos section. I went in MCS and added a new line and then moved the 'Video Library' link to that new line along with a link to the MacroTube app. I named it 'Videos' and saved it. Than I went back and renamed the old line to 'Pictures' and saved again. This time, I know its doing something becuase the name change applied when I loaded 7MC. The 'Video Library' link was also gone from that line, but the new line I made was no where to be seen.
3. Id like to remove the Sports line altogether. I went into MCS and unchecked that line and saved, but its still there when I load 7MC.
So am I missing something here or am I trying to do things that just arent possible with the software currently available. Any suggestions would be appreciated.
post #1565 of 4573
9/4/10 at 8:49am
- trooper11
- offline
- Thumbs Up: 11
oh and this is surely a simply thing, but I cant figure out how to point MB to launch tmt3 when trying to play movies i have ripped to bdmv folders. When I choose such a movie, the screen flashes for a moment and then goes back to MB. I assume thats becuase its trying to use 7MC to play it back.
post #1566 of 4573
9/4/10 at 10:00am
- smokarz
- offline
- 2,921 Posts. Joined 2/2007
- Thumbs Up: 31
thanks for looking into this Green. but it didn't work (for me at least).
i gave up. i am going to rip the AAC track and convert it to AC3. a little more work, but probably have a chance of working. thanks again.
post #1567 of 4573
9/4/10 at 9:28pm
- RocShemp
- offline
- 591 Posts. Joined 11/2001
- Thumbs Up: 11
Yup. That's definitely what I'm seeing. Well, as long as the bug is just that ReClock is reporting it wrong, I'm fine with that.
post #1568 of 4573
9/5/10 at 4:11pm
- Bob Sorel
- AVS Moderator
- offline
- 8,117 Posts. Joined 1/2000
- Thumbs Up: 11
Hi GreenEyez,
Thanks for your guide and your help previously with 108024p! To make a long story short, I nuked and paved Windows 7 and reset up MPC-HC according to your guide (using ffdShow), but added ReClock into the mix. Everything is working great now, though I have not tried 24p again, as I really messed up my system trying to do so the last time...
I have never used any kind of front end before (including 7MC), so I installed Media Browser (no plugins yet) as recommended in your guide. I started out by creating a test location for my movies like this:
F:\\Movies\\Alice\\Alice.FLAC.DTS.mkv
F:\\Movies\\Anaconda\\Anaconda.FLAC.DTS.mkv
F:\\Movies\\Beauty and the Beast (2009)\\Beauty and the Beast.FLAC.DTS.mkv
etc. (one movie per folder, all of them .MKV)
I have a total of 26 movies that I put in this area in order to test out MB's meta data retrieval. I only included the year in parentheses for a couple of the movies that might confuse MB (like Sherlock Holmes and Mysterious Island). When MB was finished downloading, I only had 6 entries in the window out of 26. I tried using the "update Library" tool, but that didn't help.
Do you have any idea why MB found only 6 of the titles (and BTW, the ones it found did not have a date)?
Another question - Is Media Center Master an alternative to Media Browser or something that should be installed in addition?
post #1569 of 4573
9/5/10 at 4:30pm
- Bob Sorel
- AVS Moderator
- offline
- Thumbs Up: 11
Also, where is the metadata kept? For some unknown reason one of the titles "Sahara (2005)" MB has retrieved cover art for a James Belushi film. I of course wanted the Matthew McConaughey film and I would like to replace the data manually. I can not find the James Belushi film either at Netflix or IMDB.com, so I have no idea where MB is getting this info from.
post #1570 of 4573
9/5/10 at 4:36pm
- dbone1026
- offline
- 10,909 Posts. Joined 8/2008
- Thumbs Up: 31
Media Center Master is a metadata retrieval tool. You can use it to gather your metadata for your movies for Media Browser to use instead of relying on Media Browsers internal. I prefer using a 3rd party metadata tool (I use metabrowser) for gathering metadata, and then use Media Browser as my front end (launching MPC for my Blu Ray mkvs)
post #1571 of 4573
9/5/10 at 4:51pm
- Bob Sorel
- AVS Moderator
- offline
- Thumbs Up: 11
Thanks for the tip, Damian! I am glad that you explained that to me as I would be getting frustrated very quickly if I had to rely on Media Browser's internal metadata retrieval abilities. I have a HUGE library of ripped Blu-ray .MKVs, and before I go to the trouble of putting them all into individual folders I want to make sure that the metadata can be retrieved fully and correctly...
post #1572 of 4573
9/5/10 at 4:54pm
- dbone1026
- offline
- Thumbs Up: 31
Here is a writeup I did a while back on using metabrowser to gather metadata for MediaBrowser ( I have about 400 movies and 1600 tv shows):
http://www.mediasmartserver.net/2009...h-metabrowser/
One thing to mention, the new metabrowser (2.0) is not free, however the metabrowser version I used in that guide is still free (and I actually still use it to this date). You can download the free version here if you want to try and follow along, or you can try Media Center Master
post #1573 of 4573
9/5/10 at 5:19pm
- Bob Sorel
- AVS Moderator
- offline
- Thumbs Up: 11
post #1574 of 4573
9/5/10 at 9:44pm
- jrolmstd
- offline
- 266 Posts. Joined 7/2008
- Thumbs Up: 10
Stupid noob question but when the guide says the following, just what is being installed?
Installation:
-> At the Setup Tab, choose Custom instalation
-> From the dropbox, disable the following : DirectVobSub , AC3 filter, Xvid, DivX MKV, Haali, Thumbnail components.
-> Select Next and Complete.
Installation:
- GreenEyez
- offline
- Thumbs Up: 16
- GreenEyez
- offline
- Thumbs Up: 16
Hi GreenEyez,
Hi GreenEyez,
Hy Bob. No problem, glad to be of help. Hoep the 24 switching works this time around.
Media Center Master, as dbone said, is a metadata retrieval tool. It gets better synopsis that the internal MB scrapper (10-20 lines vs 4-5 lines) and can automatically rename and move/organize your movie files to folders, so you don`t have to do it manually for your entire collection. That`s the way it`s set up in my guide, and once you minimize it it runs in the background with no other user interaction required.
Regarding Media browser, there is a bug that prevents MB from searching the library for new items instantly, it happens 45 seconds - 1 minute after you start media browser. Did you leave MB on for that time?
The developers have fixed the bug in the new version (Orion), which will be out on 30 September. I can hook you up with the Orion beta, but the CovertArt plugin doesn`t work with it yet (since it will only be updated when Orion hits the final stage)
First let MB on for 45-1 minutes to see if it adds the new movies, if not try clearing the cache (in the configurator)
Metadata is stored in a cache folder, while MCM stores it in each movie folder, including post/backgrounds + xml info file.
- GreenEyez
- offline
- Thumbs Up: 16
Go in the external players tab in the Media Browser Configurator and add TMT3 (the uMCEDVD.exe) for Blu ray.
Regarding Media Center Studio . An update from 7MC from MS screwed up MCS some time ago, and it seems the devs haven`t been working on a fix.
Basically you can not remove the default entry points or strips, just add new ones, and rename entry points if you want. Use this to remove menu strips : http://dl.dropbox.com/u/10837046/hid...nterstrips.exe
post #1578 of 4573
9/6/10 at 6:50am
- Bob Sorel
- AVS Moderator
- offline
- Thumbs Up: 11
Thanks, GreenEyez!
Yup, MCM did the trick very nicely. You know, I had read your guide over several times and did not know whether the use of MB and MCM was an "either" or "or" situation, and I did not want to install anything more than I absolutely needed. Now I know - you NEED MCM or other similar program like dbone uses. I was going to try out dbone's guide, but I already had MCM in hand so I took the lazy route.
As far as the 24p situation is concerned, it was not your fault...
The old Catalyst drivers that I was using just had too many problems, and rather than update the drivers, I figured I would nuke and pave since I also had too many codecs installed. Now I have a nice lean machine with no extra baggage to screw things up and it is working perfectly, though like I said, I have not yet tried 24p. I probably won't bother, either, since all audio and video is silky smooth and in sync (maybe because of ReClock?).
I am going to play around with MCM today to try out the automatic naming and organizing that you informed me about. If it works properly it will be a HUGE convenience, as I have a quite a large library of ripped Blu-rays that need to be put into folders and may possibly require renaming.
I guess the most important thing is that I am now having FUN instead of frustration...
The old Catalyst drivers that I was using just had too many problems, and rather than update the drivers, I figured I would nuke and pave since I also had too many codecs installed. Now I have a nice lean machine with no extra baggage to screw things up and it is working perfectly, though like I said, I have not yet tried 24p. I probably won't bother, either, since all audio and video is silky smooth and in sync (maybe because of ReClock?).I am going to play around with MCM today to try out the automatic naming and organizing that you informed me about. If it works properly it will be a HUGE convenience, as I have a quite a large library of ripped Blu-rays that need to be put into folders and may possibly require renaming.
post #1579 of 4573
9/6/10 at 7:51am
- Makaveli6103
- offline
- 322 Posts. Joined 4/2008
- Thumbs Up: 11
post #1580 of 4573
9/6/10 at 7:55am
- dbone1026
- offline
- Thumbs Up: 31
post #1581 of 4573
9/6/10 at 8:36am
- Bob Sorel
- AVS Moderator
- offline
- Thumbs Up: 11
...and can automatically rename and move/organize your movie files to folders, so you don`t have to do it manually for your entire collection.
I can rename files just fine, but how do you "move/organize your files to folders" using MCM? I tried reading the Wiki, but it is very incomplete.
I was able to get the job done using "file2folder GUI" from dbone's guide, but I was under the impression that MCM could do that without the need to use an external program.
- GreenEyez
- offline
- Thumbs Up: 16
Yes, it can, see here in the screenshot. You need to put the movies that need to be processed into one folder (name it whatever you want), then point the "completed downloads" to that folder, tick auto-rename, auto-move and auto-fetch metadata. Then point "Move movie downloads to.." to your Movie folder.
Then click "Save" and press Ctrl+P When you want MCM to start.
Note: Ticking "Automatically detect new video files and process them..." makes MCMC automatically scan that folder and do this auto, without the need to press Ctrl+P
PS : You don`t necessarily need MCM, the integrated Media Browser scrapper worked fine for me almost a year for example. I only moved to MCM because it get`s better (more comprehensive) metadata and more backdrops (sometimes higher quality ones) than the internal MC meta-scrapper + it saves in the movie folders not in the MB cache folder, so it`s easier to manage and edit.
post #1583 of 4573
9/6/10 at 11:06am
- trooper11
- offline
- Thumbs Up: 11
Thanks alot for that tool, that at least allows me to remove the strips i dont want. Hopefully MCS can be fixed becuase it has alot of potential. I still cant add strips though. I can rename existing ones and sort of make it work, but custom new strips dont show up at all.
I saw a few 'hacks' to try and allow MCS to work normally again, but none worked for me.
Thanks for looking into it.
post #1584 of 4573
9/6/10 at 1:11pm
- trooper11
- offline
- Thumbs Up: 11
Just a follow up on the Media Center Studio issues.
For anyone that is struggling to get it to work, I have found the method that worked for me to get most functionality back.
Use MCS and reset MC to default
Rename all files in the folders:
C:\\ProgramData\\Microsoft\\eHome\\Packages\\MCEClientU X\\DSM
C:\\ProgramData\\Microsoft\\eHome\\Packages\\MCEClientU X\\DSM-2 (Note: I did not have this folder on my system)
Create a new text file with the same name as the old file. (StartResources.dll)
Set as read-only.
Change permissions to not be inherited from parent directory.
-Go to Properties>Security tab>Advanced>Change Permissions>
-Uncheck the box 'Include inheritable permissions from this object's parent' and then choose 'Remove' on the box that pops up
-Apply and close windows
Load MCS and recreate your custom layout
Launch MC
The above method allowed me to add custom menu stripes and such, although I still cant change the order of the menu stripes. Those changes dont show up in MC.
UPDATE:
Well I was wrong about moving the order of menu stripes, I can now do that too, so Im very happy now lol.
Set as read-only.
Launch MC
UPDATE:
post #1585 of 4573
9/6/10 at 5:00pm
- Bob Sorel
- AVS Moderator
- offline
- Thumbs Up: 11
Thanks, GreenEyez! I will give it a shot on the next batch. I learned a lot today because I found that MCM could not identify quite a few of my movies by the way that I had them titled. I also found that a couple of the movies had no cover art, and even one title had to be misspelled in order for it to match up with IMDB...
I would like to try out your "Black and Titanium" theme, but I don't know how to get it into MB. The only way I could find to install themes was from the MB configurator, and it does so by downloading from a list. Your theme is not on that list, so I figure that I have to manually copy the files in your archive to somewhere, but where?
Also, if you load, let's say, 5 themes via the configurator plugin, what happens? Which theme will MB use? Or will it create total chaos? I'm good at creating chaos...
Oh, and where is your donation link?
- GreenEyez
- offline
- Thumbs Up: 16
The black & titanium theme is for the entire Media Center, not for Media Browser. I use the Diamond theme for my MB set-up (and in the pictures). You need Media Center Studio to change the 7MC theme. Just load the .mct file from the theme you want to use, and click Apply.
For changing the Media Browser theme that is being used, just look up in the Media browser configurator at the "display" tab, down below, is a visual theme entry. You can change it from there. There is also a small wrench (or something similar) when you are in the Media Browser view in 7MC, see screenshot, from which you can enter the MB options and can change options just like in the configurator.
As for the donation link, it`s that "Donate now with paypal" image, click, it`s actually the donate link, linked to that paypal image. It was the only way to make something similar to the pp button
- GreenEyez
- offline
- Thumbs Up: 16
Set as read-only.
Launch MC
UPDATE:
Set as read-only.
Launch MC
UPDATE:
Nice find. I`ll test it out tomorrow and add it to guide, i also need to change the order of my menu strips.
post #1588 of 4573
9/6/10 at 7:08pm
- Axel
- offline
- 4,461 Posts. Joined 3/2002
- Thumbs Up: 11
.... You need Media Center Studio to change the 7MC theme. Just load the .mct file from the theme you want to use, and click Apply.
I have tried this on (3) different systems, all W7 Ultimate, (2) 64 and (1) 32 bit. Every time I try to import a .mct file, MCS crashes with a 'stopped working, CLR20r3' error message. MCS version is BETA 0.0.6.5. I have tried different .mct files that I downloaded here from the forum.
Any idea what I am doing wrong?
TIA!
____
Axel
post #1589 of 4573
9/6/10 at 7:14pm
- Bob Sorel
- AVS Moderator
- offline
- Thumbs Up: 11
post #1590 of 4573
9/6/10 at 10:03pm
- Makaveli6103
- offline
- Thumbs Up: 11
- Windows 7 Media Center : Setup Guide, Knowledge Base & Support
Currently, there are 1961 Active Users
(489 Members and 1472 Guests)
Recent Discussions
- › Energy Owners Thread 40 seconds ago
- › Hannibal on NBC 1 minute ago
- › Whatever happened to DCM's Steve Eberbach? 1 minute ago
- › 100k speakers vs 1k speakers! 2 minutes ago
- › $1500 max budget. Your choice of speakers for Classic Rock. GO! 2 minutes ago
- › My HT\2ch setup 2 minutes ago
- › Slow write speeds on FlexRaid (RAID-F Snapshot RAID) 3 minutes ago
- › B&W Owner's Thread 3 minutes ago
- › The Official Xbox One thread... 3 minutes ago
- › Seaton Sound SubMersive1 4 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
