AVS › AVS Forum › Video Components › Home Theater Computers › Windows 7 Media Center : Setup Guide, Knowledge Base & Support
Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 61
post #1801 of 4560
I had Alex help me with my computer and I can't think of a better computer experience in my life. Very highly recommended to all in question.
post #1802 of 4560
Hope to try his skills this weekend.
post #1803 of 4560
Lol, i was actually wondering why you didn`t PM me back with the TeamViewer ID and pass. This weekend works fine for me (althought Sunday afternoon i`ll be out so i won`t be available).
post #1804 of 4560
Just for everyone's info, I have found that MB 2.2.8 breaks ts playback through MPC-HC.
MPC-HC fails to launch, and 7MC tries to play the file and fails with "Windows cannot play the video file" error.
restoring my sys back to prior MB 2.2.8, fixes the issue, but now I don't have MediaInfo as I upgraded;(
post #1805 of 4560
Strange, have you reported it on the Media Browser forum?
post #1806 of 4560
I can confirm this too. Although a few files open MPC, most are now just played internally.
post #1807 of 4560
I am using the software setup guide above (with Shark007) to playback MKVs in Windows Media Center for a Win7 64 setup and seem to periodically have playback freezing during video, every couple minutes. Video cant be resumed- need to restart video - multiple times during movie. If I play the mkv in Windows Media Player(x64) it plays fine. Any ideas what I could look into.
post #1808 of 4560
just a note if anyone else runs into this issue.
I was having an issue where MC would force my screen res to drop and an error to occur cuasing MC to crash, which then allowed the res to restore to its proper setting.
this happened after i changed from one monitor to another. after spinning my wheels for a while on the issue, I found out from a poster here that Media Control caused that exact issue for him. All I had to do was uninstall and reinstall Media Control and the problem went away.
Im not sure what about Media Control was cuasing the problem to begin with, but it must lock/force a certain res from within its settings. Just something to check if you run into a similar problem.
post #1809 of 4560
So I have everything setup using MPC HC as an external player and all seems to be well. The only things that really bother me are that when I pause I can’t really tell how much time is remaining. Also the fast forward and rewind are a little kludgy. Are there any solutions to this?
I am afraid of switching to the internal Windows player because on my TEST PC I was never able to get things set up correctly. Shark codec pack seems a little shady to me. Anyone else think this or am I just crazy??
Also Is the internal video player better quality in any way as far as performance compared to MPC - HC?
Also does anyone have recommended settings for ATI Catalyst?
Thanks A Bunch!!!
post #1810 of 4560
Hi all, I was wondering if anyone has had this problem and what is a fix. I had to reload my hard drive and all sw. Now when using WMC7 when in full screen I can not see my mouse pointer. If I am not in full screen mode it is fine. Any Ideas please?
post #1811 of 4560
First of all I would like to thank GreenEyez for this guide! I first installed it back in June and it worked great. To say I'm new at this is putting it mildly
The problem is the PQ seamed low(washed out) thought it was the video card,so I upgraded to a ATI HD 5750 not much help every thing looks good until the movie is played,they are video_ts no compression.Followed the guide for P1-a MPC-HC and P2 MB tried MCM in beginning had problems and uninstalled it. OS Win7 32bit,ATI 10.9 monitor HansG 21(dvi) TV Sharp Aquos 32 (HDMI) Any ideas as to low PQ?
post #1812 of 4560
Northwestern,
Pardon me if this is already in the guide, but did you try the WMC black level registry fix?
WMC looked very washed out (blacks were grey) on my Pioneer plasma until I tweaked a value in the registry? I am over-simplifying this but it has something to do with WMC outputing 16-235 colors instead of 0-255 colors or vice versa.
http://www.hack7mc.com/2009/06/fixin...ck-levels.html
I tried both settings (value of 1 and a value of 2) and one of them really improved my picture.
Hope this helps,
post #1813 of 4560
Anyone?
Originally Posted by terminaldawn View Post
So I have everything setup using MPC HC as an external player and all seems to be well. The only things that really bother me are that when I pause I can't really tell how much time is remaining. Also the fast forward and rewind are a little kludgy. Are there any solutions to this?
Thanks A Bunch!!!
post #1814 of 4560
Anyone?
For time remaining, press O (or select options) in MPC-HC,select Keys and assign a remote button to the App Command field of Remaining Time. It's keyboard shortcut is already set to Cntrl + I.
Sorry FF & Rew and kludgy on mkv. Use prev and next chapter where you can.
post #1815 of 4560
Awesome. Thanks this is helpful!! Do u think it's worth it to try and get the internal player in 7mc to work?
post #1816 of 4560
Welcome.
No, you have more flexibility and less codec issues with MPC.
post #1817 of 4560
Go in the CCC settings and set the Dynamic Range to 0-255.
post #1818 of 4560
@terminaldawn - You can also use the jump forward/back keys to jump every 30-1 minutes ahead, see here.
post #1819 of 4560
GreenEyez That did it, took 2seconds to set and over a month to get the courage to ask the question Thanks again for the help and especially the GUIDE any newbee could follow
Thank you
post #1820 of 4560
any ideas on why using Media Player on it's own sounds and to some extent looks so much better than Media Center ?
post #1821 of 4560
I don't think it does. 7MC works great with just a little tweaking. Its fast, plays everything out there, and is integrated natively with W7. I've tried XBMC, MP, and one other I can't remember, and after trying for days to get stuff configured and set up, I went with 7MC which does everything natively and intuitively and effectively. I think 7MC looks great also.
post #1822 of 4560
Originally Posted by tehowell View Post
Thank you. What about this one?
Did you install the complete Catalyst Suite, or just the individual components (DD and CCC)?
That would seem to be the ATI Catalyst Control Center for those of us that are acronym challenged individuals...
Reading where AMD bought ATI, is this product compatible with Intel?
thanks
post #1823 of 4560
And you can change the small, medium, and large jump times under tweaks. I have my fast-forward/backward remote buttons set to jump forward/back by 7.5 seconds. The remote cursor right/left buttons jump by 60 seconds, and the remote cursor up/down buttons jump by 15 minutes.
post #1824 of 4560
Guide update :
Tomorrow : Remote controlling your 7MC/Media Browser interface from a webbrowser or Android/iOS device and media streaming to these devices will be added to the guide.
@GreenEyez
thanks for your excellent guide!!
Just started the setup of WMC...
Any news about when you'll add the above to your guide?
post #1825 of 4560
Hi everyone! Thanks for such a helpful guide!
I have a Win 7 x64 setup running 7MC with Media Browser (I don't have any need for a BluRay player right now). I have been ripping my DVD collection to MKV using MakeMKV and it works well. However, I'm having issues when trying to use Fast Forward and Rewind options when playing these files. The jump forward / skip back works fine. But it definitely seems like there are some issues with fast forward and rewind actually working.
I noted several post mentions of Media Control possibly fixing this. I've also googled a bit and can't seem to find anything (or might not be googling the correct terms/words). I didn't exactly follow the guide here because I found this guide first on the Hacking Windows 7 Media Center blog.
So a couple of questions (or any other info would be greatly appreciated):
1) Does Media Control work with MKVs and other formats with the latest 7MC? If not, are there any workarounds to get the FF and Rewind to work better?
2) Does Greeneyez guide fix this and should I try to update my system via this guide?
Thanks in Advance!!
post #1826 of 4560
i've always wondered why the skip forward/back aren't good enough....
once i started using the skip buttons, i never have touched my ff/rew buttons.
my mother has the same issue, she refuses to skip through commercials on her recorded tv, but instead insists upon actually fast forwarding through them.
never understood why.
[shrug]
post #1827 of 4560
[shrug]
We use the skip forward/back definitely for TV especially for commercials. But I guess I'm not really into pressing the jump forward button 10-30 times to get to a point in the show/movie that we want to watch. And we have just gotten a wireless keyboard/mouse so I realize we can use that to point directly at the spot we want to go on the timeline.
I guess I'm more annoyed by the "bug" that the fast forward / rewind buttons on the remote do not do their job for all files.
post #1828 of 4560
post #1829 of 4560
Originally Posted by puckalicious View Post
It's been 30 pages since I've looked at this thread, any update to a possible fix for PGS subs in MakeMKV or in Another EAC3toGUI?
Well, the issue is not MakeMKV related but it is related to the splitter/subtitle renderer being used. I had posted the issue on Doom9, but it looks like until the Matroska Splitter gets redone the issue will remain.
post #1830 of 4560
MPC-HC seems to work fine with PGS subs created by MakeMKV, but ffdshow DXVA didn`t load a set of PGS subs created by MakeMKV when i tested it at somebody`s HTPC.
@TapND - Yes, ff/rw are not supported by default in MKV, only in other formats, Media Control does this, enables ff/rw and subtitle switching. If you are using the ffdshow software decoder you don`t need to do the modifications for the ffdshowDXVA one presented in my guide.
