AVS › AVS Forum › Video Components › Home Theater Computers › Windows 7 Media Center : Setup Guide, Knowledge Base & Support
Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 95
post #2821 of 4570
+1 . MPC-HC 64bit only works with ffdshow 64bit, and vice versa, either the official versions or the latest SVNs linked by dbone. And 64bit brings 0 improvements to a media HTPC, since 2GB is more than enough for a HTPC that only does media playback or ripping.
post #2822 of 4570
greeneyez/dbone
thanks all is well. Went back to using 32bit setup via your links.
i need to stop tinkering and leave things alone.
post #2823 of 4570
Originally Posted by goondog View Post
rex6b10
hey i just posted a similar issue on damians website. I was also using 32bit in past but newly installed 64bit and downloaded new versions of mpc and ffdshow.
i got the in the mpchc settings and no ffdshow in the add list also.
my avr just shows pch multichannel and 7.1 but im not getting any sound out of surrounds.
also the ffdshow icon in my tray isnt popping up.
is yours? hopefully someone can shed some light or may go back to 32 bit. tired of fresh installs!!
7.1 multichannel is probably your Windows config default output? Are you using shark007 or ffdshow solo install?
post #2824 of 4570
When downloading a couple movies and running playon as an extender on my I7 740 laptop I'm nearly maxing out my 4gb ram. That's why I have decided to use win 64x and 6gb ram in my Htpc. I'm constantly making out my 4g ram.
post #2825 of 4570
I had shark007 but switched to ffdshow solo. Everything is working well via the guide on page 1 now. I have a decent PC but if 32 works without issues thats what im sticking with.
post #2826 of 4570
Guys, this is probably not the best thread to ask, but could anyone point me to a good resource for calibrating the color for my video card? I have an ATI Radeon 4800 connected by HDMI to my LCD. Running Windows 7 x64
Thanks for the tip.
post #2827 of 4570
Thanks for the tip.
Possibly this:
http://www.avsforum.com/avs-vb/showthread.php?t=1187234
And This:
http://www.avsforum.com/avs-vb/showthread.php?t=948496
post #2828 of 4570
dbone, you're the man...as usual.
post #2829 of 4570
guys, i am having trouble playing TS files in 7MC.
are my settings messed up? need an external player?
any software to convert these TS files to something more common, like MKV or MPEG?
thanks
post #2830 of 4570
thanks
Can you be more specific, what type of TS files, what video codec, audio codec, etc... For example VC-1 TS will not play in 7MC unless you hack things up, same thing goes for True HD (see an excellent post from Renethx explaining)
post #2831 of 4570
sorry, it's VC-1 True HD....
wow....this is going to be a mess to get this to play in 7MC.
anyway of converting the file to an AVI, MKV, MPEG, etc.?
post #2832 of 4570
You could hack up WMC a little using a codec pack like Shark. My preferred method, use MPC HC as your player and have it launch from WMC (via Media Browser or Mymovies), so no hacking needed
post #2833 of 4570
i also tried MPC-HC, but all i got is a black screen.....
post #2834 of 4570
With the shark007 codecs installed,
set the suggested settings checkbox and then . . .
for an mkv, on the mkv tab, set gabests' splitter
for an m2ts that originated fram a BD, set the blu-ray splitter on the mpg~mp4 tab
Media Center will now be able to play that file.
post #2835 of 4570
So your m2ts VC-1 won't even play in MPC HC? That is odd, do you have any other stuff installed on your PC? Also, in MPC HC Go To View -> Options -> Internal Filters and make sure that MPEG PS/TS/PVA is checked under Source Filters.
post #2836 of 4570
it is checked....
i got audio...but no video, just a black screen..
post #2837 of 4570
it is checked....
Are you using the latest SVN for MPC HC?
post #2838 of 4570
build: 1.3.2090.0
mpc compiler: MSVC 2008 SP1
ffmpeg compiler: GCC 4.5.1
post #2839 of 4570
May not fix your problem, but latest version for MPC-HC is 1.5.1.2931
http://www.xvidvideo.ru/component/do...installer.html
post #2840 of 4570
thanks, but didn't solve the issue...
could the file be corrupted?
post #2841 of 4570
What is the original source of the TS file?
post #2842 of 4570
blu-ray....
it's a blu-ray REMUX video.
post #2843 of 4570
blu-ray....
Any chance it is a 1080i?
post #2844 of 4570
try a trial of tmt3/5
post #2845 of 4570
nope, 1080p
post #2846 of 4570
nope, 1080p
crap, you got me. 1080i VC-1 causes a lot of problems with players (there are a handful of BluRay movies that are 1080i). Only thing I can think of is it is a bad remux?
post #2847 of 4570
i am still doing research and saving $ to get pieces of hardware here and there.
for software I am reading this thread.
I have never build computer before so a lot to learn from here.
- I will have a 2TB as the only hard drive for the HTPC. what are the size of the partitions should there be?
- what format type should I have for these partition, NTFS?
post #2848 of 4570
blu-ray....
Just an idea, any chance it's a HD Audio Bluray of Vivaldi, say or Beethoven or Mozart?
As I have these and it's purely High Def audio and a black screen for the video.
post #2849 of 4570
Well, you will only need about 60 gb for OS HD partition (also good to keep a size that will be easy to clone and swap out for a SSD when they are cheaper), and I like to split my large HDD into partitions equal to the platters that make up the hard drive, so maybe divide by 3 or 4 if that's how many platters there are and also divide one of those into a 60 gb for the OS
eg.
2 TB = 1953 GB / 3 = 3 X 651 GB...then
C: Drive 60 GB
D: Drive 591 GB
E: Drive 651 GB
F: Drive 651 GB
Format all as NTFS, and allow drive indexing for the E and F drives if you want, helps for compression, I don't do it as I have a few other drives, but never do it for the OS drive and it's partitions.
Just my thoughts, anybody else can jump in
post #2850 of 4570
I don,t remember the exact setting, not at computer right now. I had the same thing and solved the problem I think in options renderer settings, vsync settings. Try some changes I'm sure it is there. Can only give exact settings in the weekend! Let me know sorry for the delay!
