Originally Posted by Shark007
M2TS is locked into the Media Foundation pipeline by default.
The moment you disable Media Foundation, the 'Directshow Merit system' kicks in and you can do anything your heart desires with M2TS files.
Since I have your attention, its been a very long time since you tested my software.
I even support VC1 interlaced files within m2ts or MKV for playback in the Windows players.
It is on my list to revisit and document. The one issue I have is that for my core i5 htpc I need to use the arcsoft video decoder to get dxva for vc1. I haven't checked if that is something built in to your pack or I would need to supply separately.
I also plan on doing a clean install on my amd htpc which means at least for that one I wouldn't have to worry about arcsoft
