@rexb610 - My latest guide is focused on using Clown_BD for BR folders and Another EAC3to GUI for MKV, but for ripping on your main PC, not on the HTPC.
I personally haven`t used Auto-rip & compress, i found a guide about it and included it into my guide. I will make a more detailed investigation tomorrow since it`s late (4am) where i live.
In the meantime, can you please do something:
In Media Info (once you have loaded that specific m2ts, ofc) go to View tab, select Text. Then go to the File tab and select Export.
On the Export screen, select the Text tab, click advanced mode and select the desired filename and click Ok
After that upload that txt file here.
It`s very strange that your DTS stream has a "Stream Extension". If it would be DTS-HD MA there would be a MA instead of "Stream Extension". If it would be just plain DTS, there would be no extension and you should see the bitrate.
