Originally Posted by Alterity17
So I decided to give up on 1.2 of the guide since I couldn't figure it out.
Initially when I tried 1.1(MPC-HC) I ran into some problems so thats why I never went back. Well I just tried it again and everything is working perfectly, even my DTS-HD, so that makes me happy.
Am I losing any advantage from running MPC-HC and not the internal player?
Again thanks for all the help and awesome guide
I definitely recommend using MPC HC as I find getting consistent bitstreaming with the internal player is unreliable. The nice thing about MPC HC is that it is very easy to have launched for other front ends such as XBMC if you decide to change things up (I just tested out launching MPC HC from XBMC and it works much smoother then from Media Browser)
