Originally Posted by swoon!
There sort of is, check the xvYCC box in the driver. The problem with this is that the levels get screwed up. You can read this Sandybridge review which discusses the issue. So it isn't something you really will want to do unless the driver has fixed this issue since the review.
The drivers have not updated to address this issue yet.
No other media players or apps that might f$%^ w/ shark's codec pack.
