Hoping you guys can help me, and forgive me in advance for the long post. I just want to make sure I give you all the details you need to help me, if you can.
I currently have the ATI Radeon 4800 (with the DVI / HDMI connector). I run one DVI output to my normal PC monitor. I then run the HDMI connection (which carries audio) to my AVR. When I want to watch a movie, I just put my AVR on the correct input, and the video flips over to my main TV.
The issue I'm having is that when I make this switch, Windows 7 previously switched the audio over automatically. Now, I have to go into the sound options before Windows detects the HDMI audio connection. It then switches it on without me having to select it, and identifies it as the default playback device.
I just can't figure out why it's not automatically detecting the HDMI audio connection, and requires me simply to open the sound options menu before it does finally identify it.
Any suggestions at all would be appreciated. I'm currently only using the ATI HDMI Audio driver and CCC. I don't use Realtek drivers.
