Just got done switching over to LAV/Shark007s/MadVR. Also went from MPC-HC 64 bit down to 32 bit version so I could enable MadVR. System is running on a core i5 win 7 64 bit platform. Video card is AMD Radeon HD 6670. Latest CCC installed.
Marked improvement in color and still getting the HD audio bit streamed via hdmi so good there but the video will get really laggy/choppy (audio continues fine) for several seconds that then smooths back out with audio and video synced back up.
Sharky007s is current as is MadVR. MADVr is running from a SSD so should not be hardware related. Configuration setup per instructions page one. ffdshow x64 maybe dated (v1.3836) so I need to check on that.
I had used Shark007s in the past just not with the LAV/ MADVR options.
Suggestions?
thanks
Suggestions?
thanks
