Originally Posted by
smokarz
I see. THanks i'll install your version.
I guess i don't need to go though the mpc setups with your version?
I would have responded to your 1st request about what MPC version but I do not like to suggest to people to use my codecs.
The moment you stated you were a user, I chimed in.
No setup is required within the players I release.
I also offer a version of the player that includes madVR, pre-configured and ready for use. If you already have madVR installed, I suggest you remove it to avoid conflicts. I personally see no improvement what-so-ever using madVR but I have a high-end system. If a use approaches me with visual issues, my 1st response is to uninstall the madVR version and use the 'normal' version. The only reason I offer MPC with madVR is by user request.
