AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official LG xxPK950 Owner's Discussion Thread
The Official LG xxPK950 Owner's Discussion Thread - Page 46
post #1351 of 1360
Hiya fellow PK950 owners! Anyone of you who tried the "pot tuning" tweaks talked about recently in the PZ950 thread?
If you have, please share your experience in the new thread devoted to this: http://www.avsforum.com/avs-vb/showthread.php?t=1372479
post #1352 of 1360
My 950 has been perfect for the past 2 years but tonight, I noticed a stuck green pixel
post #1353 of 1360
Unfortunately, with LG often it happens, it's good to check their panels. On my PV350 already have 6 "problematic" pixels. Fortunately not see them during normal viewing of 1.8 meters. Maybe as it will end with a warranty, I will give it to the service panel may exchange or give newer model ^^.
post #1354 of 1360
I don't think stuck pixels are limited to LG panels.
I'm not too concerned since it is not visible during normal viewing.
post #1355 of 1360
Hi, I have a Harmony xxx and was wondering if there is no way at all to enable direct input for my LG 50PK950 tv?
Just to be clear with direct input I mean being able to switch to HDMI2 with the touch of a (one) button.
post #1356 of 1360
I have a Harmony One and all of my inputs switch directly, both through my activities, and in Device mode, where each input is on a soft button.
post #1357 of 1360
Hello, I received my 60PK950 in February of 2011, so it's about 22 months old. I have absolutely LOVED this set until recently.
I've noticed a severe buzz that started about a month ago. Didn't think much of it at first as it went away, but the buzz has been happening more frequently and it has stayed buzzing for a longer time.
I know buzzing is inherent to the plasma technology. I actually returned a Samsung plasma because of it and got the LG instead.
I'm looking for insight into the issue and how to fix it. Any help is appreciated. Thanks! -Gordon.
post #1358 of 1360
I also have occasional buzzing. Especially at cold starts, but sometimes even then when it is already warmed up and the picture has lots of whites in it, which often happens for me as I'm using my desktop PC with it. If both conditions exist, the displayed taskbar might flicker as well.
I'm not sure if there is a solution to it. Let me know if you find out anything that could help, but my assumption is that more energy the TV needs, the greater the chance that it would start the buzz. rolleyes.gif
Try to change the settings of brightness/contrast/temperature/etc just to see if it is the case.
post #1359 of 1360
Hey everyone. I have tried to google for this, but I cannot find a clear answer.
I have a LG 60PK950 and am wondering if the HDMI > TV > Optical Out pass through is just 2 channel audio or does it pass through 5.1 audio?
I don't have a home theater for it. Currently just use the tv speakers. I want to buy a Samsung HW-E450 sound bar (only one optical in) for it and am wondering if the optical out will just spit out 2 channel audio only, as my bro's old DLP only spits out only 2 channel audio on its optical out from a source that is plugged into the TV from HDMI.
I mainly watch my HD cable box and apple TV on this tv. these two are plugged in via HDMI to the tv.
Any help would be great.
post #1360 of 1360
All my HDMI inputs suddenly not working. It says no signals but components inputs are working. Any idea what went wrong and what can I replace to get it work again?
