AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official LG xxPK950 Owner's Discussion Thread
The Official LG xxPK950 Owner's Discussion Thread - Page 27
post #781 of 1359
Originally Posted by Goatse View Post
I had 60A2000, it was a great tv but this one is much better.
Ah ok, I have a 60A3000. It is better than the 950 in some areas and worse in a few others. Both great sets and very underrated for the $$$ paid out.
post #782 of 1359
only thing I see worse is the slight lag which I knew of going in. A2000 picture got worse as it went on, like the color filters starting to fade a bit due to the UV light. Also picture was so very dark compared to the LG.
post #783 of 1359
LCD is virtually burn in proof so yes, it makes it a better monitor. PQ wise, plasma is better. If you play alot of games, I'd go LCD.
I just started searching for a new TV and am finding that I cannot get a straight answer on gaming. I have heard people say that LCD is better, no burn in, no lag. And then I have heard people say the exact opposite; plasma has virtually no lag, better at quick motion, etc.
post #784 of 1359
onecall
Or Vann's.
post #785 of 1359
lag really depends on the video processing of the TV not the technology. This TV is not that great with lag even in Game mode with all processing off. I prefer the plasma picture, its more natural. LCD gives a sharper picture because of the pixel spacing i think. But contrast wise a backlit screen like an lcd just isn't gonna have the good shadow detail or uniformity that a pdp has.
post #786 of 1359
I'm a Lt. Colonel on Halo Reach. If my 950 lagged, I wouldn't have been able to do that.
post #787 of 1359
As I understand input lag is directly related to the tv's processer. Most have 8 bit which is the least of the newest tv's out today. 10 is what to shoot for and I'm not much of a Sony tv fan but I was told by a big box store salesman that the xbr, nx and hx have a 14 bit. I haven't confirmed those specs yet but ultimately the better processing your tv can do the better it is for gaming.
post #788 of 1359
Originally Posted by PCHDTV View Post
Same here. Update says 5.01 is latest.
mine says 5.00.00, maybe build date/size has to do with different firmwares?? different video chips?
post #789 of 1359
My 50PK950 from Onecall was delivered this afternoon. Stand was not pre-installed. Aug. build date, firmware 5.01. What was interesting the box was not strapped to a wooden pallet as described in the Onecall shipping video. It shipped from their WV warehouse so I don't know if things are handled differently in that location.
post #790 of 1359
Guess newer models build in aug comes with .01 firmwares and stands not installed.
post #791 of 1359
I have been trying to absorb all comments on this forum, so i am not certain if this was covered.
Ordered my LG 50PK950 2 weeks ago now (awesome deal on Onecall), as well as a PS3. My main concern here is, as some users suggested, i've toned down the TV modes (for example not using vivid mode and instead of sticking with APS etc) yet i still get a ridiculous amount of IR. With the Netflix menu on the netcast or with the PS3 main menu as well (with just 1 minute set time) is this normal or it lessens with the 200hr break in period?
I set to every single image/movie i watch on this TV to FULL screen. Its just scary that there IR with just a minute settle time (multiple images have to run by in order to wash out the IR)
Suggestions are appreciated.
p.s The PQ is awesome on this set.
post #792 of 1359
That is how mine was when i picked up it from Huppins "onecall" locally.
post #793 of 1359
I am curious if you will be able to update to 6.00 firmware on that set as it is exactly as mine.
post #794 of 1359
I didn't have a ton of IR when new but it was there, the PS3 menu and Netfilx menu did stay up for a bit. I am now at a little over 400 hours and it is hardly noticeable. I still have the orbitor option turned on both my HDMI ports "cable box / PS3"
post #795 of 1359
Something must have changed during August builds. I'm an August build with 5.01 and the stand installed.
post #796 of 1359
onecall
Wow, good price. Have they added the Pandora app yet or plan to?
post #797 of 1359
6.0 still has the same apps, so no Pandora.
post #798 of 1359
Still confused why the same tv uses different firmwares
post #799 of 1359
I tried to update firmware but it said no update available
post #800 of 1359
Got the TV yesterday and I'm very impressed so far. I got it through OneCall, and the entire buying experience was great.
The optical out does not seem to pass through Dolby Digital from my DirecTV box, which is connected via HDMI. Therefore, I have the optical out from the DTV box plugged directly into my AV receiver.
However, this TV does have an optical input. If I run the optical out from the DTV box into the TV's optical input, and then run the TV's optical output into the AV receiver, will the signal simply pass through without any manipulation? I don't have an extra optical cable to try it out yet.
I suppose it is also possible that the HDMI cable going from the DTV box to the TV is crap and therefore Dolby Digital isn't even being passed to the TV??? I'm using the HDMI cable that came with the DTV box over 2 years ago. That said, my new blu-ray player didn't pass through from HDMI to optical out either.
I'm going to have to use the TV's optical out to be able to hear the audio from Netcast or external media content. Just trying to figure out if I can run the optical from DTV box to the TV, in order to save one input on the AV receiver. As it is, my optical inputs on the AV receiver are both occupied, so I'd need a converter to convert optical to coax, unless I can do what I want. OK, I'll stop rambling.
THX mode is awesome. This is a huge jump forward from my Sony GWIII rear-projection LCD, which, by the way is going to be replaced for free due to an internal melting issue.
post #801 of 1359
my guess is that in aug, when the 3D PX950 tvs were in production LG switched the video chipsets and streamlined them to both pk/px requiring different firmwares than the older build.
post #802 of 1359
Me too, I e-mailed LG about this already but got a non response back from them.
post #803 of 1359
That is the only thing that really makes any sense to me as well.
However getting LG to confirm this will probably be impossible.
post #804 of 1359
Unless I'm completely missing something, the TV does not have a digital optical (or coax) audio input. Output, yes. Any digital audio to the TV has to arrive via HDMI.
post #805 of 1359
Oops, you're right. It's a PC audio in.
Well, that certainly simplifies my options!
Thank you.
post #806 of 1359
That sucks. Maybe next year.
post #807 of 1359
get a rokubox. Only 60bux, I like it better for netflix also.
post #808 of 1359
I'm hoping Hulu gets added at some point.
post #809 of 1359
How is a rokubox compaired to a PS3? I use a PS3 for Netflix and streaming video from my file server with PS3 Media server.
post #810 of 1359
I like the roku box because, it had pretty much every streaming option thats always powered on. PS3 has to be powered on and go in to its submenu. Granted the PQ is slightly better on the ps3 but not enough hassle for me to use the ps3.
