AVS › AVS Forum › Video Components › Home Theater Computers › HD4670 - no sound with HDMI output
post #1 of 8
Hi guys, hope you can help me, dont know what else to do...
I got a hdmi cable and plugged, the sound works perfectly, with windows 7 HDMI default driver audio. I realized that is was giving only 2 channels, then I installed the realtek driver to try to solve that, then the sound stopped.
I formatted my PC and since then I cannot get any sound.
Have no luck with windows 7 default driver. I installed the R2.42 from Realtek site.
When I play some sound with the ATI HDMI output selected, the volume bar next to it becomes green, as if the sound was being playied, but NO SOUND comes from the TV. The same happens with windows default driver.
and I should have a realtek control panel right? But when I run the files inside realtek folder, nothing happens, the control panel doesnt open.
Im using catalyst 10.4, Realtek R2.42 on Windows 7 Pro x64. Sapphire HD4670. TV is a Samsung LN32B350.
My onboard sound is disabled on bios, theres no HDMI options on bios.
Anyone can help me?
post #2 of 8
Im writing one more post so the forum let me posts the screenshots...
post #3 of 8
One more...
post #4 of 8
Here are the screenshots from sound properties:
http://yfrog.com/fvatihdmij
And the registry calling the realtek control panel: http://yfrog.com/2oregistroiyj
post #5 of 8
Connected to a TV and getting 2 channel sound.
What else do you need?
The TV has only two speakers, so the system will only see those two speakers, not more.
Set the HDMI audio as default. In your pic., there's a green tick mark next to the headphones. That shows that the headphones are the default device and not the HDMI.
post #6 of 8
Sorry I think I didnt make myself clear. Im getting NO SOUND on TV, even the stereo sound. The headphone was just selecteded when I took the screenshot. Even if I select the HDMI audio output as default device, when I play something, the volume bar gets green to show the sound volume, but NO SOUND comes from TV, I hear NOTHING.
post #7 of 8
First off, disable in device manager, the SBLive and the other sound device you had and reboot. Uninstall the realtek driver and the ATI driver then reboot in safe mode and run driver sweeper to remove all traces. Reboot and install the ATI 10.4 drivers and test.
post #8 of 8
i need orientation ui have a similar problem first i had an ati radeon hd 3450 agp card have built hdmi and dvi ports iam getting image on hdmi i mean video but not sound i a different way i never get the hdmi audio option on the sound properties on my computer the specification said that ati have a b built 5.1 audio chip inside the card please help me in how to enable the hdmi option.i am using windows 7 32bit os and catalyst 10.4 for my ati radeon any help that you could give and explanation unfortunately my onboard sound still use ac97 codec i put anew 5.1 card with spdif connector thedynex 5.1 dscx-5 that use via envy24 family audio controller driver also ac97 codec, i am trying to get a hd audio sound card don't find any on the web.that could cause the problem of no hdmi audio option iam trying to coonect my pc to my vizio lcd 37" that have hdmi input.
via my ati radeon output built in the card get video not sound not evenly 2 channel sound that is my case if anyone could help me to resolve my problem
