So, I am looking into buying an HTPC. I am not looking to build my own for various reason (time, energy, etc). So ideal I would like to either have it built for me, or get an out of the box solution.
I have seen a lot of the small form factor PCs like Zino HD and the Zbox. With all the upgrades you can get in the them, they are pretty pricey. And generally there isn't a lot of room to upgrade them down the line.
I found this website (via Ebay) that sells pre-built HTPCs (www.lycomputers.com) and was wondering if anyone has bought anything from them before, and if this PC I am looking at would work for what I want it to do. I am doing mainly HTPC media, but also some gaming.
Here are the specs:
It comes to ~$1000 for this build (the prices on there are additional to the base build).
Is this a reasonable/cost effective build for what I want to do? Most of the stuff I read about the components seems positive. Obviously not top of the line stuff, but able to handle HD media and some gaming (as long as I am not looking to max everything out).
Any help, suggestions, comments would be appreciated!
Here are the specs:
Code:
LYHTPC20 Custom Media Center HTPC Computer Processor [ CPU ]: Intel Core 2 Quad Q9400 Quad-core [2.66GHz per Core] - $99.99 Memory [ RAM ] : 8GB DDR2 240-Pin SDRAM Desktop Memory - $154.99 Hard Drive [ HDD ]: 500GB 7200 rpm SATA 3Gb/s hard drive Optical Drive [ DVD ]: 24X DVD/CD Rewritable Drive Video Card [ Graphics ]: Radeon HD5770 [Dedicated Ram 1GB D-Sub,DVI,HDMI] - $129.99 Sound Card [ Audio ]: Onboard 6-Channel HD Audio Network Card [LAN/WLAN]: Onboard 100Mbps Media Drive: Card Reader Power Supply: 550W High Efficiency Dual Fan Power Supply - $9.99 Operating System: None 2nd Hard Drive: 500GB 7200 rpm SATA 3Gb/s hard drive - $59.99 2nd Optical Drive: Blu-ray Reader & DVD Reader Combo Drive TV Tuner Card: TV Tuner with Remote Control Keyboard & Mouse: None
