Originally Posted by Factoryguy
Here's my experience after the first 3 days:
1. Packing materials: My first two 63c8000 units arrived with broken panels. One was shipped direct and one was delivered by my local dealer. Samsung's packing materials for this large, heavy TV are inadequate. The resulting breakage is a waste of resources and a bad customer experience.
2. Overall picture quality: Very good right out of the box but definitely needs a full calilbration. I'm pretty happy with it so far.
3. Buzzing: Not noticeable.
4. IR: None yet, but I'm being very conservative.
5. Dead pixels: Haven't seen any.
6. Black levels: Very good - dark, stable, low noise (haven't measured yet).
7. 3D: Absolutely the best I have ever seen. (And I've seen many TV and PC active shutter set-ups.)
8. Horizontal line bleed: Faint but noticeable on high contrast objects against a bright background. The bleed is visible regardless of contrast, cell light, brightness settings. It's not bad enough to return the TV but it's annoying once you know what to look for.
Questions about the line bleed problem:
(1) Do all these TVs have the problem? On this one, rows of black text against a white background will repro the problem every time. It's faint but definitely there.
(2) Does anyone have a guess as to the root cause?
I see the line bleed as you mention - haven't found a way to reduce it
