My infinity PS-10 sub started going goofy a couple years ago. It would start to make popping and/or hissing sort of noises about 2 years ago, even when the volume was muted on the receiver. The capacitors all look okay. I wouldn't say any of them are even swollen, and the fuse is still intact.
The only thing I see out of the ordinary is on the power supply. Please see the attached pics. There are 2 layers that are supposed to be identical I am sure. The top section is a darker yellow/orange and is night and tight and smooth, and is about 1/4 inch inside the outer edge of the power supply. The bottom section is a lighter yellow/orange, and bows out quite a bit from the power supply and I can actually see inside the yellow/orange tape or whatever that is.
1) Would this most likely be the cause of my problem?
2) Can I get another power supply like this? How can I find a similar power supply? This one has 042-010053-003 YT-10616-4 ELY 0441 printed on the top of it.
Any tips, info, suggestions would be great! I would love to get this sub back up and running on my own. I am now going to pull out the woofer itself and inspect for issues there and will update with what I find.
I already live tested the amp with it plugged in and powered on to verify that 120 volts were coming in from the wall.
- Don
