Hi all,
I've been slowly building my theatre for a couple years now and I have finally had enough with the floor in my theatre room. It is in the basement of a 33 year old house and the concrete floor is quite unlevel, sloping towards the back left of the room.
I have been contemplating tearing up the flooring and using self-leveling cement to try to correct it, but lately I've been thinking of going a different route.
I was thinking of building a 2x6 wood subfloor over the entire floor of the room. I would have it carpeted with a rounded nosing where you enter the room so it would look nice. I have enough clearance in the room as it's got 9' ceilings. This way the floor would be leveled, it wouldn't be as cold, there wouldn't be as much reverberation from the concrete, and I could incorporate a sand filled "stage" inside the floor at the front as well as conduit and ducting within the flooring.
Would this be a "no-no" or would this actually be good? I had come across an article a while ago that stated:
An additional benefit of a raised wood subfloor is that it absorbs some low frequencies, which is good. Otherwise, these frequencies just reflect off of the original concrete floor. A wood floor also vibrates with low frequencies, to some extent, creating a more-tactile experience. A raised floor that has at least a 3- or 4-inch air space under it will vibrate even more. This technique is used in the screening rooms at Lucasfilm and Dolby Labs. Anthony's and Russ' clients like the added low-frequency feeling as the subwoofer's bass energy transfers through the floor.
Excerpt taken from:
w w w.hometheatermag.com/bootcamp/140/index1.html
Thoughts? Any help would be much appreciated!
Excerpt taken from:
so I started over.
