AVS › AVS Forum › 3D Central › 3D Displays › Panasonic P50VT20 amazing and frustrating!
Panasonic P50VT20 amazing and frustrating! - Page 4
post #91 of 102
Originally Posted by Frank View Post
Here is a new one I took from my boat of a local sailboat race on Lake Superior.
http://dl.dropbox.com/u/7350380/Wedn...oat%20race.MTS
Hi Frank,
Do you need to have 3D glasses to watch those clips in 3D ?
If so, which ones would you recommend ?
John
post #92 of 102
Originally Posted by jktrinh62 View Post
Hi Frank,
John
Usually the answer is yes but I suppose if you wanted to view it on a autostereoscopic display you could see it in 3D without glasses.
Otherwise....the type of glasses would depend on what kind of display you are using.
post #93 of 102
Frank,
I have downloaded several of your "3D" MTS files to my computer, but when I try to open them with Windows Media Player 11, the program says it cannot recognize or play these files. What to do?
post #94 of 102
Do you have WIN7?
post #95 of 102
Originally Posted by renglade View Post
Frank,
Why not try this?
http://www.videolan.org/
post #96 of 102
Originally Posted by almostinsane View Post
Do you have WIN7?
No, I have XP.
post #97 of 102
Why not try this?
Thanks, Frank. I downloaded the VLC player, and it is able to open the MTS files. The video starts to play, but the image remains frozen on the first frame, like a snapshot. I'll keep experimenting with it.
post #98 of 102
No, I have XP.
Win7 has all the codecs that make playing MPEG4/h.264 files painless and transparent. Older versions of Windows require that you install other codecs. It can get hairy. That's one of the main reasons I've upgraded to Win7 on my systems, except for one that still uses some legacy hardware/software. As soon as I can, I'll upgrade that one, too.
post #99 of 102
Does anyone here use the Kazaa Standard Codec Pack and Media Player Classic? My favorite set of codecs and players
post #100 of 102
Could you upload a sample of your homemade 3d video, id like to try it on my set.
post #101 of 102
After reading all these stories, I was fearing I would need to go out and buy a BluRay burner just to watch some of the samples and videos available on the net. Tried calling Panasonics' Tech Support and they couldn't even tell me the type of formatting a USB needed (only supports FAT32, not NTFS)! Of course they had no clue what I was talking about when I asked them about the video formats supported... All they could say was that they supported most video formats generated by Panasonic video recorders, and that they didn't not support common formats like mp4, avi, mov, or mkv... in this time and age... unbelievable!
At any rate, via trial and error, here's what worked for me in case it helps others:
1) Obtain a copy of a side-by-side 3D video (don't worry about formats yet)
2) Use a video converter program (I use Xilisoft Video Converter Ultimate)
3) Based on Panasonic's manual, I tried all the AVCHD and H.264 formats but they weren't recognized by the TV or Blu-ray Player
4) Finally, converted the video into "HD-Xvid Video" (Xvid HD Video Format) which generated a .AVI file
5) Copied the file to a USB, plugged it into the Blu-ray Player and clicked Play
6) It showed the side-by-side video, so on the TV, chose Viera tools, 3D, and switched from Auto to Side-By-Side
7) Voila! Put your glasses on and enjoy!
TIP: Depending on the size of your 3D video, it is very likely you'll exceed the 4Gb limitation of the FAT32 format. So as part of the video conversion, you can split the video. I opted for ~4Gb segments which you can easily copy to the USB or burn to a regular DVD (Blank Blu-rays are still expensive...)
post #102 of 102
off topic but i went to my cousins house and he has a VT-20 iwas like holly.
the pq is awesome but i dont know if the 2011 3d panny will be better
  Back to Forum: 3D Displays
