I just ordered Comcast's Digital Preferred package and want to connect my Win7 MCE HTPC so I can watch live TV or DVR for later viewing. Comcast is providing a DTA box but don't have it yet so I'm not 100% sure what I am getting.
Any recommendations or advice on a TV Tuner card for my HTPC so I can do the IR Blaster kludge? Needs to be low profile to fit in my case
Does the IR Blaster trick allow you to schedule DVR'ing shows from any channel with win7 mce?
Background:
I know some of the channels under 30 will be clearQAM, I want both encrypted and unencrypted channels
I have read this DTA to MCE setup article, if I get the right card it should be doable
I don't want to spend $400 on the Centon cable card tuner
When I built the HTPC 6 months ago my original intent was to get a HDHomerun dual but now that Comcast uses DTA's that won't work. I have searched but not found way to do the IR Blaster hack. The HDHR cable card unit isn't out yet and I am not waiting for that. If I could use an HDHomerun with the DTA that would be my first choice
Mike S
Background:
Mike S
