My goal for my theater room is to use higher quality speakers of medium size while maintaining great source separation on surround sound soundtracks. I have no idea what theory, setup, or misconfiguration I am lacking so I am asking for help.
Currently, I can either set up my small satellite speakers for 5.1 surround and get tinny, but well defined location-sound. With my "real" speakers, everything sounds great, but the sound field blends together and nothing really stands out.
Front RL: B&0 RL140 (wall mounted straight towards listener)
Center: B&W center 150watt (below TV angled upwards)
Rear RL: B&W 602s (as suggested by the 5.1 layout (against side walls facing listeners ears)
Sub: 150 JBL
Receiver: Yamaha 95w RX-N600
The other problem is the room may be too small for the speakers I own. The room is about 20ft x 12ft with the 20ft wall hosting the TV.
The other (maybe related) issue is that usually, the music overpowers everything, including voice and sound effects. It feels like I am not getting good dynamic range (maybe to due power needs?) I have messed and played and researched but I am missing some concept or hint to point me in the right direction.
*checked all dynamic range settings
*distance configured
*speaker polarity verified
Thanks a bunch for your time and knowledge!
Sub: 150 JBL
