AVS › AVS Forum › Other Areas of Interest › Camcorders › Pirate batteries for the Panasonic HDC-HS/SD/TM700?
Pirate batteries for the Panasonic HDC-HS/SD/TM700? - Page 2
post #31 of 32
Has anyone found a 12v adapter that can power this camcorder? Thanks.
post #32 of 32
Just stumbled on this... you should look into it:
http://cgi.ebay.com/Charger-Panasoni...item3ef0c921c0
Same seller sells batteries that work with TM700, just so you know..
  Back to Forum: Camcorders
