So I wasn't sure where to post this, but figured people would see it here. I know there is a lot of interest in electronic masking and the other day I built a system for myself. The building of the project only took the better part of a day. I thought about the project for weeks, but the building went smoothly.
Here are photos of the screen open at 178 and closed at 235. There is also a linked video showing the screen masking motion in real time.
VIDEO Download
http://www.cir-engineering.com/bin/masking/masking.wmv
I got most of the parts from www.av-outlet.com Here is a parts list of what I got from them.
I went to a metal shop near me and got 1.25" round tubes for the rollers and 0.5"x1" rectangular metal tubes for the masking bars. Please note: You CAN NOT use a ferrous tube for the motor tube. This motor uses magnets to know where it is, and to memorize the stops positions. If you use a steel tube, your motor will not work correctly at all. You must use an aluminum tube for the motor tube.
I went to a craft store and got some black fabric for the masking.
Here are more photos.
Top Right 178
Bottom Right 178
Top Right 235
Bottom Right 235
Top Left 235 (see wound up cables)
Bottom Left 235
Cable to Masking Bar
I got many original ideas from this thread on AVS http://www.avsforum.com/avs-vb/showthread.php?t=1219694.
Here is a quick explanation...
The motor goes inside the roller tube at the top right. The tension spring goes in the roller tube at the bottom right. The top and bottom round tubes are attached with the brackets and plastic bearings from av-outlet to a 2x4.
The fabric is taped to the round tubes with Gorilla tape. The fabric is wrapped twice around the masking bars and is again taped to the bars with Gorilla tape.
The top mask falls by gravity as it unwinds. The bottom mask is pulled up by coated metal cables attached to the bottom masking bar. The cables wind up around the top round tube. The cables are held to the top round tube with hose clamps and are held to the bottom mask bar by wire fasteners (available in the electronic section of HD).
The spring in the bottom right round tube pulls the mask back down when the mask is opened. The motor pulls the top mask up when the mask is opened.
The "U" channel holds the masking bars at the sides. I wrapped the ends of the masking bars with Velcro so there would be a smoother motion of the moving parts.
A 2x4 is anchored into the drywall about 2.5" from the boarder of the screen. These 2x4's hold the roller tubes and all hardware.
I would estimate that the entire project cost around $400.
Questions?
craigr
VIDEO Download
- Somfy LT30 IR Round Head 1.25" 12VDC Roller Shade Motor.
Somfy LT30 - IR1 - Single Channel IR Remote Control (Required for programming stops).
Three Rollease RB360 Shade Brackets.
Two Rollease REP03 End Plug for 1.25" Tubes.
AVO 12VD100W - 12VDC 1A White Wall Plug Power Supply.
Rollease SAPE03-RIGHT Pin End Spring Assist - 1.25" - RIGHT.
Top Right 178
Bottom Right 178
Top Right 235
Bottom Right 235
Bottom Left 235
Questions?
craigr
