Originally Posted by joel27nc
Mark - I see you are correct. The DST is back on. TVGOS must change it. I also turned off my updates, TVGOS still gets updated. It appears the CM tech support is throwing crap at me. Which means they lied to me about software updates to stream internet stuff & be able to set your DVR while not at home, through the internet. Suppost to happen in the next 9 months now. Hum. Thanks for your help.
That's too bad. Don't give up completely on new firmware being released. There is no telling what, if any, features could be added, but it sounds like they told you exactly what you wanted to hear.
Mark
- But, is better now than when first released a few years ago - it's just not for those wanting everything perfect.
, no green light) the antenna's signal is routed through the DVR and on to the TV by coax. When the DVR is turned on the normal OTA coax output to the TV stops and the HDMI feed is available. Often, if I'm just going to watch TV for a few minutes (for news, weather, etc), I don't turn on the DVR and just use the TV's tuner, instead. But, for watching half-hours shows or longer, I want the pause feature that the DVR supplies. It is great to be able to pause for a phone call, potty break, etc, and then pick up where I left off. I can then skip through commercials to catch back up to live TV.
