AVS › AVS Forum › HDTV › HDTV Recorders › Channel Master CM-7000PAL HD DVR - AKA Dish DTVPal
Channel Master CM-7000PAL HD DVR - AKA Dish DTVPal - Page 13
post #361 of 609
Originally Posted by videobruce View Post
The unit formats new drives when they are installed. I would assume if you did a full erase with the manufactures utility or possibly a low level format, the unit will treat that drive as new.
Maybe someone else can chime in here.
Should I format FAT32, NTFS or Linux?
post #362 of 609
Don't, the machine will. Just wipe the drive.
post #363 of 609
I read that one of the glitches with this recorder is that when you have one program being recorded (say from 9 to 10) and then you have two shows to be recorded right after it (from 10 to 11) that it will not record 1 of the two shows at 10. Is this correct?
post #364 of 609
Look through the FAQ's, I believe it's a know issue.
post #365 of 609
Does anyone know when you purchase a CM7000pal at Walmart did you have 30 days or 90 days in which to return it? --thanks--
post #366 of 609
Can someone help me out...
I'm trying to keep HD programming "Auto" but stretch SD programming to fill my 46 inch LCD. Can this DVR not do both? I know on the Dish network DVR's you can select an option for both the HD and SD programming.
However here, when I try to set the SD programming to "Auto" it moves the HD programming to "stretch" mode. If I set the HD to "Auto" it moves the SD to partial.
In settings under installation I have HDTV to 16:9 and I've tried both SD under 4:3 and 16:9.
Any help would be appreciated.
post #367 of 609
Hi yragha,
You can control the zoom size independently by using the page up and the page down button, one make change to the HD output and the other one make change to the SD output.
darmand
post #368 of 609
I still can't get it to work for me....
EX: We have channel 2.1 which is HD, I have HD set to Auto (page down) and all is good. The next subchannel is 2.2 and it's SD, I have it set (page up) to Stretch. I will stretch on the screen but when I flip back to it later it reverts to the black bars around the picture.
What gives?
The Dish DVR that my parents have is easy, say you flip to TVLand (SD only on Dish) you just adjust the picture format button. Say you flip to USA (HD on Dish) you do the same and the settings stick.
post #369 of 609
You have 90 days from date of purchase. Which I translate as 90 days from date of order.
post #370 of 609
Anyone know what the latest firmware version for the CM7000PAL is?
post #371 of 609
New CM7400 model.
post #372 of 609
There is a whole thread on it;
http://www.avsforum.com/avs-vb/showthread.php?t=1360146
At that price point & additional fee for the Guide, I doubt it will sell.
post #373 of 609
Just got my new Channel Master CM-7000PAL last Friday - works great, still learning all features. And, I used sponsor: Monoprice, for hookup cables and adapters, great prices and they always have everything I need. My 6-year-old JVC HD-VCR has worn out heads, too expensive to repair, so DVR will now do my time-shifting of new Fall lineup programs, incl. Charlie's Angels.
Thanks to member(s) posting discount code for Channel Master store that saved 10% on online purchase.
post #374 of 609
I've had mine less than two weeks. First freeze last night, with loss of recording. We had a single recording scheduled, and a second single recording the following hour. We were watching the recording in progress, playing catchup, but at the top of the hour, the Pal froze. The red light was on, and about 6 minutes later, the Pal shut itself off and the red light went out. We got all of the first event, and the 2 minute buffer of the second event. It apparently stopped recording at the top of the hour, about 6 minutes before it shut itself down. Searching on the old thread, I've found various explanations, including this advice: Don't watch a currently recording program as it ends.
Otherwise, I do like the Pal. I was prepared for the possibility of the other negatives:
1. It's the weakest tuner for multipath signal fluctuation. Making the Pal first in the antenna chain is actually worse, as the Mag2160 amplifies the signal it passes through. The Mag (first) and TV (last) show minor glitches with a fluctuating signal, but the Pal loses the lock.
2. The Pal remote is unresponsive with TV backlighting on. The learning remote works, but the Pal remote must be <6" from the Pal to work. The screen's too bright if I shut off the backlight feature, and the only loss is that the Pal remote is useless as a secondary remote. I used it long enough to notice that the Pal's remote is more likely to freeze on classics in B&W or windowbox frame, or with LPs (weaker signal).
3. I've gotten timer conflicts after deleting a timer that would be in conflict with how I want to edit a remaining timer. I know that's an old bug, and that I have to delete both timers and start over. I wish it were as vigilant in warning about one recording followed by two recordings.
4. We have two full pages of guide, and it uses PSIP data for 7 subchannels, the full schedule of ION and CW, plus ThisTV, a subchannel of ABC. I haven't figured out how it decides what to show in PSIP, but at least it's an improvement from what it cut with my TR40.
post #375 of 609
Is there a way to jump between two recording shows once recording has started on both?
post #376 of 609
Try the "RECALL" button...
post #377 of 609
Thanks my parents said that worked (we got them one of these for their bday recently...they really like it)
post #378 of 609
What would be interesting, but extremely unlikely, would be for Dish to add support for their new internet streaming service based on Blockbuster.
At this time, it's only for existing Dish Network customers, but I understand that it will eventually be available as a stand alone service as well. Since they'll be adding the software to their existing ViP DVR series, it would be neat to see this added to the OTA DVR's they developed as well.
post #379 of 609
This device has no affiliation with Dish at all. This is a Channel Master product. Adding Blockbuster streaming, Netflix streaming and/or Amazon instant streaming in addition to Vudu would all be excellent ideas -- but you won't see them on this product which was already at the end of its life-cycle when they started selling it. If offered you will most likely see streaming options on the new CM-7400.
post #380 of 609
My parents DVR got off by an hour today...seems like it got DST a month early? Anyone know what's going on? I tried to have her turn off the DST observed option but the time is still off. Does it come through the TVGoS data?
post #381 of 609
Same problem here, off by an hour and the daylight savings time setting will not change. The guide is now useless for recording as it is all off by an hour.
post #382 of 609
Where are you guys located? I wonder if it is based by cities. I checked mine last night after 10 PM PDT and it looked fine. I am in Los Angeles/L.A., CA, USA.
post #383 of 609
My parents are located in Rochester Hills, MI (near Detroit)
post #384 of 609
The time problem is the result of stations failing to understand PSIP and jumping the gun.
The PSIP data transmitted by each station includes data fields for the daylight savings time transition. It has values for the day of month and hour of the transition and normally these are zero. When the transition is less than a month away, they should be updated to the correct values.
The transition happens on 6 November this year. But if you set the day to "6" on 6 October rather than the 7th...
Things will return to normal tomorrow. This isn't hard and is covered reasonably well in the standard: A/65.
I did a quick check and all but two of the major stations in DFW screwed this up.
post #385 of 609
So this is not TVGOS' times? Would telling TV stations about this problem do any good? My recordings better be on time tonight.
post #386 of 609
Might want to make the recording continuous for hours and take into account the time shift. I doubt it will fixed today.
I always hate when you can't manually fix the times on devices....never seems to work perfect when set to auto.
post #387 of 609
[sighs] Ditto on the manual fix.
post #388 of 609
my recordings better be on time tonight.
or
post #389 of 609
Originally Posted by Pete-N2 View Post
or
Or I will be upset. :P
post #390 of 609
I am in Canada and all but two of the stations I receive have correct date time on them. Of the two that are incorrect one is off by almost two months (says it is is Aug. 9!) and the other has no date or time info and I don't normally watch either of these channels so I don't think this is PSIP causing this problem.
  Back to Forum: HDTV Recorders
