Originally Posted by
Kelson
This device has no affiliation with Dish at all. This is a Channel Master product. Adding Blockbuster streaming, Netflix streaming and/or Amazon instant streaming in addition to Vudu would all be excellent ideas -- but you won't see them on this product which was already at the end of its life-cycle when they started selling it. If offered you will most likely see streaming options on the new CM-7400.
I can easily make you eat the crow
- do you see that dish word "PAL" in the name ?
- do you have a slot on bottom with E* smart card ?
- is your CM-7kPAL has unique Rxx number (plus a lot of unique bytes in OTP area of flash what must be engage when payTV or VOD or DOD, etc will come) ?
- isn't a PCB inside marked as "Design in UK. E*" ?
I think it's enough to dismiss your mistake.
