"I think the splitter is behaving as designed"
I agree. It is not designed so that the hdmi ports are separate in their logic. Both ports default to the lowest common denominator.
I'm sure we'll see splitters that are designed to keep each port separate.
"you'd need a firmware update on the AVR"
Sorry but it is not the case that just a firmware update will allow a 1.3 receiver to handle 1.4 information. IF a receiver is designed to do so and just needs to be updated, like some of our displays, yes a firmware is needed. But if a receiver is 1.3 and its hardware is 1.3 a firmware update will not change its hardware design.
