AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Need DVD to replace sony vhs cue/review features
post #1 of 6
This may seem like an odd request, but I've used older style Sony VCR's in my everyday work. ( Horse racing analysis / review that involves constant cue and review, often stepping back a few seconds, forward a few seconds, use of 2x speed, etc ) The older Sony vhs models ( slv-1000, slv 676, slv 575, etc ) are perfect for this, with a jog button, and both search /ff / rewind buttons
The problem is it's getting harder to get these old machines. I usually junk a good one when it dies as. 9 out of 10 sold on Ebay usually have problems
I need to see if anyone knows of a dvd player that can come close to the quickness of the cue and review features on those old vhs machines. Quick, near instantaneous response is a must. I prefer NOT to use a computer to review this video material, as it's just too cumbersome
Any suggestions are appreciated
post #2 of 6
Never actually used one myself, but the Pioneer DVD-V5000 Professional DVD player looks like it might be good for your situation.
post #3 of 6
The Magnavox H216MW9A or new MDR513H std def DVD recorders with HDD might serve your needs well.
Besides the normal FF/REW, they can search by time, move fwd and back in user-set increments with SKIP/REPLAY rocker button, Mark up to 6 spots in a recording for easy return, frame advance, slow-play w/o audio, slo/fast replay w/audio (0.8X and 1.3X), and more.
Here's a help file that describes most of the play options.
Here's a help file describing the DISPLAY menu with several playback-control features incl. search, Marking, etc.
Most play-mode movements (FF/REW/NEXT/PREV) and pause-mode movements (frame advance, slo-mo) are "instantaneous" on HDD and DVD recordings. On DVDs only, large moves such as SKIP FWD/BACK and NEXT/PREV (chapter moves to uer-settable time increments up to 5 min.) may take ~3 sec or so.
Click #1 in my sig. for a complete list of other info and help files
post #4 of 6
Thanks guys
Wajo, apparently you wrote the book, an amazing amount of info on these recorders!
Could you answer one question for me
I believe you posted the that the time required to complete a variable replay from button press to play on a 2160 ( playing a dvd ) was appx 3-4 seconds. Does that same time frame apply for multiple button presses, say maybe 2 presses for variable replay or maybe a variable reply + variable skip??
Basically, can I do a couple quick button presses and still get back to the play mode within 4 seconds
post #5 of 6
Originally Posted by Rick Johnston View Post
Thanks guys
I think you're just asking about timing on a DVD since the "3-4 sec" only applies to them... I have to change that to 3-5 sec by the way, seems to vary based on how big or small the move is... smaller takes longer, don't know why? I used 1-min SKIP, 30-sec REPLAY in my initial tests.
For DVDs, the SKIP/REPLAY moves are the only ones that are slow, ~3-5 sec, and they won't accumulate like on the HDD. You really have to wait for a move to almost end before pressing for another move. HDD moves are near instantaneous and can accumulate.
Both SKIP/REPLAY and NEXT/PREV moves are user settable in the increments described in the help files.
post #6 of 6
Understood and thanks
For my particular use that would almost mandate a copy of a dvd to HDD prior to using
  Back to Forum: DVD Players (Standard Def)
