Originally Posted by
leviathan18
have you tried mkv and streaming dts ma or dd hd ?
I've read your review several times, but after the extended use, do you think is the best htpc out there for 3D ?
Works great with bitstreaming with ffdshow tryouts and MPC-HC for MKVs. You have the silent stream 'bug' which is not an issue if you don't switch files in your playlist every minute or so. This is a nVidia issue, but I don't think it is very serious unless you have lots of media which are all of short length.
I don't personally believe in 3D (the only access to 3D TVs I have is not at home), so this HTPC was just tested for the basics of 3D stuff at review time. After that, it has just been functioning as a regular 2D HTPC
This is absolutely the best high end pre-built HTPC you can get at the moment. If you are building one yourself, and don't care about 3D, use a Clarkdale with a ATI 5570 (try to get a passively cooled model).
