The specifications of the ASRock Vision 3D HTPC systems are already to be found
here for the Blueray version (Vision 3D 135B) and
here for the dvd version (Vision 3D 135D). Click on 'Product Specifications'.
I have no idea if ASRock wants us to see the specs already
Specifications
CPU - Intel® Core™ i3-350M Mobile Processor
- Support Intel® Core™ i7 / i5 / i3 Mobile Processor Family
OS - Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant
Chipset - Mobile Intel® HM55 Express chipset
Memory - 2 x 2GB DDR3-1066MHz
- Support DDR3 1066MHz, 2 x SO-DIMM slots, Max. up to 8GB
VGA - NVIDIA® GeForce GT425M Graphics, NVIDIA® 3D Vision Capable
HDD - 500GB ,7200 rpm
- Support 2.5" SATA HDD
ODD - BD Combo / DVD Super Multi
I/O - 1 x HDMI
- 1 x DVI-I
- 5 x USB 2.0
- 1 x S/PDIF
- 1 x eSATAII
- 1 x USB 3.0
LAN - Gigabit LAN
Sound - 7.1 Ch HD Audio with THX TruStudio PRO™
WiFi - 802.11b/g/n
Remote Controller - MCE Remote Controller
Power Unit - 90W/19V Adapter
Dimension - 200mm(W) x 70mm(H) x 200mm(L)
Volume (liters) - 2.8L
.jpg)
.jpg)
