Originally Posted by Flask
Just updated our 32LE5400 to firmware version 08.03.00, and it seems to have knocked out the TV's ability to play videos off a USB stick. I can select the USB stick, but the TV reboots a couple of seconds after bringing up a list of videos. Anyone else having this problem?
I've formatted the USB stick NTFS to hold videos greater than 2 GB, but that's never caused a problem in the past.
Andreas
I hadn't had any problem since the update until last night. I, too, have an NTFS formatted USB stick. On it were a couple of categorized folders, and a root directory with additional videos. Navigating into a folder and selecting a file played it without any issues. Even highlighting a file in the root directory caused the TV to reboot. I figured I had somehow corrupted my thumb drive or the files were just bad; I had not associated the behavior with the firmware update of last month.
Has anyone discovered anything? I will try a FAT32 thumb drive tonight as well as an NTFS hard drive with identical files and see what happens.
