Code:
DISC INFO:
Disc Title: SPARTACUS
Disc Size: 43,439,998,572 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.4
PLAYLIST REPORT:
Length: 3:16:44 (h:m:s)
Total Bitrate: 27.87 Mbps
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 21995 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 3491 kbps 5.1 / 48 kHz / 3491 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio French 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics English 30.923 kbps
Presentation Graphics French 28.681 kbps
Presentation Graphics French 0.022 kbps
Presentation Graphics Spanish 27.193 kbps
FILES:
Name Time In Length Size Total Bitrate
00010.M2TS 0:00:00.000 3:16:44.501 41,117,190,144 27,865
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size
Max Frame Size Max Frame Time
1 0:00:00.000 0:07:44.547 17,768 kbps 22,910 kbps 00:04:02.325 19,108 kbps 00:00:06.131 18,565 kbps 00:00:06.172 92,624 bytes
640,459 bytes 00:00:10.010
2 0:07:44.547 0:06:20.421 27,011 kbps 35,769 kbps 00:09:53.926 33,477 kbps 00:09:51.299 31,895 kbps 00:09:48.296 140,822 bytes
425,773 bytes 00:07:47.550
3 0:14:04.969 0:04:59.966 23,386 kbps 30,490 kbps 00:15:48.489 28,630 kbps 00:16:15.349 28,527 kbps 00:16:11.303 121,923 bytes
316,192 bytes 00:15:33.349
4 0:19:04.935 0:12:50.936 21,621 kbps 33,881 kbps 00:24:15.245 32,753 kbps 00:24:12.284 31,514 kbps 00:24:09.030 112,723 bytes
369,835 bytes 00:24:34.764
5 0:31:55.872 0:11:16.967 22,160 kbps 29,096 kbps 00:33:30.800 27,859 kbps 00:33:26.587 27,005 kbps 00:33:21.499 115,534 bytes
318,753 bytes 00:40:14.453
6 0:43:12.840 0:09:50.131 20,241 kbps 29,110 kbps 00:43:51.795 28,001 kbps 00:43:49.335 27,001 kbps 00:43:47.291 105,528 bytes
312,292 bytes 00:49:40.811
7 0:53:02.971 0:08:43.689 23,775 kbps 32,442 kbps 00:56:03.693 31,334 kbps 00:55:59.439 30,211 kbps 00:55:55.018 123,954 bytes
329,317 bytes 00:55:26.781
8 1:01:46.661 0:18:31.318 21,276 kbps 31,333 kbps 01:12:01.191 29,264 kbps 01:06:44.417 28,573 kbps 01:06:38.953 110,921 bytes
343,293 bytes 01:07:24.290
9 1:20:17.979 0:21:28.412 22,828 kbps 34,591 kbps 01:25:31.668 33,554 kbps 01:25:31.793 33,234 kbps 01:25:27.956 119,013 bytes
355,293 bytes 01:28:21.129
10 1:41:46.391 0:06:08.951 21,020 kbps 30,617 kbps 01:44:28.971 28,247 kbps 01:44:27.344 26,876 kbps 01:44:43.777 109,590 bytes
289,874 bytes 01:47:13.468
11 1:47:55.343 0:10:22.413 21,784 kbps 31,544 kbps 01:57:38.009 29,724 kbps 01:56:40.201 28,679 kbps 01:56:35.780 113,573 bytes
333,280 bytes 01:55:39.265
12 1:58:17.757 0:12:25.536 23,299 kbps 35,499 kbps 02:02:58.079 33,247 kbps 02:02:58.079 33,042 kbps 02:02:58.204 121,471 bytes
323,208 bytes 02:03:09.924
13 2:10:43.293 0:19:18.699 21,200 kbps 35,205 kbps 02:19:36.868 33,201 kbps 02:19:33.865 32,132 kbps 02:19:32.989 110,527 bytes
335,283 bytes 02:19:43.750
14 2:30:01.993 0:30:54.352 21,982 kbps 36,802 kbps 02:38:12.983 35,347 kbps 02:38:12.149 34,867 kbps 02:38:11.231 114,603 bytes
324,549 bytes 02:30:03.995
15 3:00:56.345 0:09:12.552 21,066 kbps 28,415 kbps 03:10:07.896 26,056 kbps 03:08:51.153 25,064 kbps 03:09:20.557 109,829 bytes
312,083 bytes 03:10:08.897
16 3:10:08.897 0:06:35.603 23,563 kbps 32,879 kbps 03:11:16.590 31,762 kbps 03:11:16.214 31,316 kbps 03:11:12.377 122,859 bytes
365,670 bytes 03:16:39.370
STREAM DIAGNOSTICS:
File PID Type Codec Language Seconds Bitrate Bytes Packets
00010.M2TS 4113 (0x1011) 0x1B AVC 11804.334 21,995 32,454,859,587 176,550,152
00010.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 11804.334 3,491 5,151,442,896 29,831,535
00010.M2TS 4353 (0x1101) 0x82 DTS fra (French) 11804.334 768 1,133,232,128 6,640,032
00010.M2TS 4608 (0x1200) 0x90 PGS eng (English) 11804.334 31 45,629,227 262,615
00010.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 11804.334 27 40,125,067 230,034
00010.M2TS 4610 (0x1202) 0x90 PGS fra (French) 11804.334 29 42,320,297 241,985
00010.M2TS 4611 (0x1203) 0x90 PGS fra (French) 11804.334 0 32,256 209
Video: MPEG-4 AVC Video / 21995 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 3491 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
