Denon finally posted information on their website for their new HDMI 1.4 receivers.
AVR-1911
http://www.usa.denon.com/ProductDetails/5330.asp
Product Sheet
http://www.usa.denon.com/AVR-1911_Lit521.pdf
Owner’s Manual (English)
http://www.usa.denon.com/AVR-1911-OM-E_006.pdf
Owner’s Manual (Spanish)
http://www.usa.denon.com/AVR-1911-OM-S_006.pdf
AVR-1911
$599.00
Thrilling Surround Sound Performance
Featuring the latest high resolution audio decoders, including Dolby TrueHD and DTS-HD Master Audio, formats found on Blu-ray discs, the AVR-1911 is also equipped with Dolby Pro Logic IIz, which provides the option of front height effects channels, for a dramatically expanded front soundstage. Pro Logic IIz also breathes new life with your stereo audio sources, providing enveloping surround sound.
Equipped With HD Radio
In addition to conventional AM and FM tuning, the AVR-1911 also features HD Radio. With HD AM radio sounds like FM, and HD FM radio sounds like CD.
HDMI 1.4a Includes 3D Blu-ray Compatibility
The AVR-1911 includes the latest HDMI 1.4a specification, which provides 3D Blu-ray pass-through (Broadcast and Blu-ray) capability, as well as providing Audio Return Channel. There are 4 HDMI inputs, along with standard definition and component video inputs. Standard definition video sources such as VCR and DVD are upconverted to HDMI, which allows for a single HDMI cable run to the TV, avoiding the expense and hassle of multiple cable runs.
Easy Setup With Automatic Room Acoustic Correction
Audyssey MultEQ dynamic room acoustic correction system features a microphone (included) to automatically measure the speaker configuration and provide acoustic tailoring for the best surround sound experience, and provides quick and easy setup. Dynamic Volume minimizes jarring volume jumps during commercial breaks, and Dynamic EQ provides a natural tonal balance even at very low volume levels.
AVR-791
(Basically same as the AVR-1911, but without HD Radio, see FAQ below for more info)
http://www.usa.denon.com/ProductDetails/5308.asp
$499.00 MSRP
Product Sheet
http://www.usa.denon.com/AVR-791_Lit517.pdf
http://www.usa.denon.com/AVR-791-OM-E_009.pdf
http://www.usa.denon.com/AVR-791-OM-S_009.pdf
AVR-1911
Product Sheet
AVR-1911
$599.00
AVR-791
$499.00 MSRP
Product Sheet
I was thinking about 12V triggers
Unfortunately, the AVR-1911 has lower wattage then the AVR-791.
the second I saw that they were using that 6ohm spec for the 3-digit models I had a vision of how many times we are now going to have to answer the exact same question from people wondering why one has more power than the other
