Originally Posted by
batpig
FYI - the "Parameter Check" menu just gives you a "report card" summarizing the results of Auto Setup. It doesn't change when you make changes to the Manual Setup menu, it stays static as a reference.
all looks normal. change fronts to "Small" with 80Hz crossover, and raise the xover on the surrounds to 80Hz also.
no, not unless one of the cables was defective.
Thanks Batpig... I made the change to 80hz for the xover the fronts and rears and left the sub alone. I am guessing this should mean when i play 2 channel direct or pure direct, the sub should switch on to help with the frequencys below 80hz... that's what my 2805 did.
On a side note, I saw on the denon uk website that the 2311 got a 5 star award from What Hifi
http://www.denon.co.uk/site/frames_m...detail&Pid=458
Not saying what hifi are the most respected source of reviews, but they gave the 2310 a award last year too, so makes me feel good about the purchase.
I am struggling to get my remote to work with my 10 + year old Marantz CD player CD63 -MKII KI Signature... I went through the onscreen remote programming and found Marantz in the list, but it does not respond. I setup the sony dvd player with no problems. The old 2805 worked fine with the marantz.... I know it's got some Philips techonology behind it.. could it be i should look around for some other codes?
