Hi,
I've got a Magnavox H2160MW9A and basic cable on the TV in my bedroom. It was working fine (5 months) until this morning when Comcast (California) switched to all digital.
I hooked up their digital converter box (Digital Transport Adapter) but the dvr has to be set to channel 3 making the timer recordings virtually useless.
I called Comcast (4x) and they ended by saying there's nothing they can do if the dvr won't accept a cable card.
I called Magnavox/Funai and they had me connect the cable directly to the the dvr and use the setup feature that cycled through all the available digital channels. It does receive some channels but none of them are in sync with the basic cable channels, i.e. the menu on/in the converter box attached to the TV in the living room shows that 63 is TLC, and through the dvr is a foreign language channel.
I've gone through all the channels that are available through the dvr thinking I could just set the dvr to the "new" number but I don't see TLC, Discovery, nor many of the other channels I normally record and only one local channel (CBS). Also, I don't see how that would work even if I found TLC because the channels were listing as 63.1, 63.7, etc. So, I have no idea how to program that into the dvr.
Magnavox said their unit is working fine and that it's the cable company's fault.
So, is there work-around? Is there an external adapter that holds a cable-card that will make the unit work?
Is there a way to make the dvr intelligently read the incoming digital signal?
Rock
Rock
but am pretty lost. Still have old analog CRT TVs, and this is my first attempt at a DVR.
