AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *OFFICIAL* Denon AVR 391 / 591 / 1611 Owner's Thread
*OFFICIAL* Denon AVR 391 / 591 / 1611 Owner's Thread - Page 54
post #1591 of 4583
the receiver cannot "downconvert" from HDMI to component out, so you need to use component video from the Blu-ray player for the time being.
post #1592 of 4583
Okay, still need some help with the remote.
So I have the 1611 remote set up to control my blu-ray player (LG), my TV (panasonic), and the Apple TV. I have the BD and ATV set to Quick-Select 1 (BD), and 2 (SAT/CBL). Now when I hit Quick-Select 1, the input source changes, but I cannot control the BD player using the remote. I need to hit the BD button on the remote to do that. Same for the ATV (hitting the QS2 only changes the input source, but to change the remote mode I need to hit the SAT/CBL button as well).
So I effectively need to hit two buttons every time I change the source. Is this the way it is supposed to work, or am I missing something? How are the Quick Select buttons different from the Source buttons above them?
thanks!
post #1593 of 4583
thanks bp,
let me summarize component video (blue, red, yellow) and 2 chanel audio from blu ray to avr,
from avr to tv can be standard video (yellow)(monitor out) and 2 chanel audio(sat) ?
I guessed this was input from tv to dvr !!
Is there an output video from dvr to tv?
No connection from blu ray to tv directly?
thanks
post #1594 of 4583
BahamaNYC -
It might be easier for you to understand if you look at the picture on p. 13 in your Owner's manual. Component in to the AVR can only go to the TV as HDMI out. You'll have to use either S-Video or composite video in and then composite video out to the TV.
post #1595 of 4583
thanks!
Yes, indeed this is how the remote works. You must first let the remote know which source you have selected by pressing that button on the remote in order for it to use the correct remote codes. Likewise in order for the remote to know you want a button to control the amp, you must first press AMP button. The Quick Select buttons are different in that they each store a number of unique settings for that particular source as noted on p. 34 in your manual.
post #1596 of 4583
Makes sense, and confirms my understanding of the quick-select buttons. I guess, my hope was that the quick-select also stored the selected device, and activate the corresponding remote.
A related question: is it possible to change the remote device without actually changing the input source? For example, can I turn off the BD player while watching a different source without first switching to the BD player?
post #1597 of 4583
Well, technically yes, although awkward at best. If you selected the BDP using the remote, then used a Quick Select to turn on the new source, you could likely then still use the remote to turn off the BDP, but you'd have to give it try to be sure.
post #1598 of 4583
Ok I have another question. On the ps3 running netflix if the sound is stereo it will pass through to the tv when the unit is off, but will not pass 5.1 to the tv. I have not tried any other source material yet. Just wanted to see if anyone has the same issue or a work around.
post #1599 of 4583
There's no reason for a TV to be able to play DD 5.1 audio, so simply set the PS3 to stereo if you're unable to pass a DD 5.1 source. Although AFAIK, there are only a few DD+ Netflix movies available.
post #1600 of 4583
Originally Posted by batpig View Post
those banana plugs should absolutely fit the AVR and the speakers, they are standard sized bananas and in fact I use that specific model. I have used those bananas on many different Denon AVR models. How are you determining that they do not fit? Does the banana not insert into the hole at the end of the binding post??
the only ones that don't always work are the "dual" bananas, because the spacing is wrong... but the actual tip size is standard for all banana plugs so there is no reason it shouldn't work.
can you provide a photo? is it a little tab that covers the "hole" on the end? If so, you might just need to remove the tab and then the banana will fit.
well, after reading BatPig's assurance that the banana plugs I got from Monoprice DO fit both the receiver end and the speaker end of the 591-BA I tried with more brute force and lo! they do in fact fit both ends. I must stop handling this AV stuff with such delicacy...
As for the celluloid tabs on the front of the speakers, my spouse just ripped them off,and nothing fell apart. Still wonder what their function was.
thanks to all who have helped me with this project.
Caroline
post #1601 of 4583
I have a BluRay movie with DTS HD sound. For some reason, my Denon receiver is showing a display of Multi Ch-In for surround instead of DTS HD. Why is it doing that? When I try to change the surround sound mode, I don't get the option to change it to DTS HD.
Please advise, John
post #1602 of 4583
Please advise, John
Hi tancreto, most likely a setting on the BD player and/or you have to manually select the DTS-MA soundtrack on the BD disc track.
post #1603 of 4583
In the blu-ray set up, the only choice is English 5.1 DTS-HD master audio...it doesn't let me change the selection. I have a samsung player with the most recent firmware upgrade.
post #1604 of 4583
Is the player set to put out pcm or bitstream?
post #1605 of 4583
pcm...should it be bitstream (re encode or audiophile)?
post #1606 of 4583
pcm...should it be bitstream?
If you want the receiver to show what it is decoding yes. However you will lose the menu button sounds. I run mine pcm on the slim ps3 cause it will still show what the video and audio is by pressing select
post #1607 of 4583
Set it to Bitstream Audiophile.
post #1608 of 4583
ok, now when I switch to bitstream (re econode or audiophile)...I get the DTS surround showing up on my Denon receiver. I think it should say DTS-HD though.
post #1609 of 4583
On the back of the disc box does it say pcmcia audio or does it have cya-bd listed. I het the same thing on speed racer which is pcm "uncompressed" audio
post #1610 of 4583
I got it from redbox. I only have the disc. It says DTS HD. http://www.wintersbonemovie.com
post #1611 of 4583
I found the back cover image...it doesn't say either.
http://images.blu-ray.com/movies/covers/14491_back.jpg
post #1612 of 4583
What tv model do you have? Is it connect from receiver to tv via HDMI or HDMI/DVI?
Try turning Off HDMI-CEC on your tv set.
post #1613 of 4583
I have a panasonic viera plasma TH-50PX6U. The HDMI connection is from receiver to TV. I don't see an option for HDMI-CEC.
post #1614 of 4583
Panasonic calls its HDMI-CEC feature "Viera Link".
post #1615 of 4583
I don't have that setting. I have had this plasma for over 3 years.
post #1616 of 4583
Ok, then its called "Control With HDMI".
post #1617 of 4583
thanks JD & BP
I'm good, got everything working.
post #1618 of 4583
Could be an issue with the disc itself. Get a hold of another DTS MA-HD disc and give it a try. You might also want to reset the microprocessor (p. 51).
post #1619 of 4583
I currently have an old Yamaha RX-V650 7.1 setup. I'm considering getting an AVR-591. The 791 would be nice, but I can get the 591 for $250 cheaper.
I have a pair of Phonic P6A active monitors:
http://www.phonic.com/en/p6a.html
Would these speakers be suitable for using as Surround Back speakers? I would then be able to use the pre-outs on the 591 to get full 7.1, and save the money I would have to spend on a 791.
Does this sound feasible?
post #1620 of 4583
Is there any way to get the Bose (I know, terrible) Cinemate GS series ii that me parents bought to work as sound with Denon AVR 591.
Right now there are HDMI cables from the devices to the AVR an HDMI from the AVR to the TV and an optical cable from the tv audio out to the Bose optical in.
