The purpose of Dyn EQ is to boost the bass and surround audio at volume levels below 0db. If you prefer to reduce that effect, you can set the Reference Level Offset setting to either 5db, 10db, or 15db for that particular source. The purpose of Dyn Vol is to equalize the volume so that not only loud explosions are tamed but also so that softer dialog is increased as well.
Additionally, if neither of these settings suits your needs, you're always free to just lower the surround channel volume using the button on the remote to better suit your preference without effecting the Audyssey filters.
Why connect to the AVR at all when you can connect directly to the TV or an HDMI switch?
