AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › DIY Constant Height › Where do you buy velvet online for DIY masking?
post #1 of 17
Hi all -
I went to Joann Fabrics this weekend in the hope to start my DIY masking project (two simple 8' long foam boards wrapped in velvet to friction fit to my existing Elite screen). However, the cheapest I could find was $27/yard and I need about 6 yards. Can anyone recommend an online retailer that has cheaper black velvet? Was thinking paying more like $5/yd.
Cheers.
post #2 of 17
I would also post on the construction forum. You might get more input there.
Art
post #3 of 17
Fabric stores almost ALWAYS have coupons in the paper that will cut the price by at least 50%. Other than that, I would follow Art's advice and go check out the construction forum.
post #4 of 17
You can usually go to joann's website and print up a 40-50% percent off coupon or as suggested their print ad will usually have one as well.
online the price seems to be about the same and then you have shipping.
http://www.bymichelle.com/fidelio.html
post #5 of 17
You can get Black Plush Triple Velvet on E*bay for $7-8/yd shipped. That's what I used for my screen border (bought from syfabrics 2 years ago).
--Dan
post #6 of 17
Contact these guys. Ask for Tim Griffin. Let him know you are from AVS forum via myself.
post #7 of 17
Hello alougher, If you read my thread, just under this one ( finished my diy curved screen with pics) you will have the info you are looking for. Hope that helps,
George (tr6).
post #8 of 17
--Dan
I have bought from syfabrics direct. They are a good source.
post #9 of 17
Hancock fabrics (online). Madonna velvet. Black as any sample I saw + some. Normal is $16/yd but it's regularly on sale for less.
post #10 of 17
Why not just buy it here?
http://www.syfabrics.com/View.aspx/P...Velvet/681/264
Numerous posts about this material, all good results from what I remember.
post #11 of 17
Thanks all - looks like syfabrics is the popular bet. I will order some from them.
Thanks again.
post #12 of 17
Joannes is handing out 50% off coupons on and one item starting next Sunday. I took it to Hancock's today and they honored it on JB Martin Fidelio Black velvet. Regularly $24.95 yd.
post #13 of 17
I could not find the Fidelio velvet on Hancock's website. Which store did you get it from? The only place I can find it is on bymichelles.com. I need 9 yards of it, so the 50% coupon will be big saving for me. Has Joann stopped carrying Fidelio velvet?
post #14 of 17
Is this material pretty solid? As in could it be used for curtains and block out light? I have blackout shades on all my windows, but i need decorative velvet to make the curtains out of, but it still needs to be pretty opaque because there is still some light bleed around the edges of the blackout shades.
*Edit
I just saw and option for ordering a swatch for $1.00 so i think ill do that and test it out myself.
post #15 of 17
Velvet also comes in ribbons
Same places that sell velvet also sell it in rolls of ribbon. Black velvet ribbons come in 1 inch, 1.5 inch, and 2 inch widths. Costs much less to frame around a projected image with this.
post #16 of 17
Sorry if this this considered OT: Has anyone used black car carpet for masking? I am currently using it as side wall light control and this stuff is a total light sponge. When used in large areas, not only does it absorb light, it also provides a neat acoustic enhancement as well. Basically I have no slap echoes at the screen end of my room, so the only 'echo' I hear are those in the sound mix. Affordable too.
post #17 of 17
Guys,
I am also planning to apply some masking to my sidewall, but I want it "removable" as my wife won't allow me to put it up permanently
I am not really hands-on on tools, any idea what's the easiest way to do the masking? Will it be using fabric or the black car carpet?
  Back to Forum: DIY Constant Height
