Originally Posted by lovingdvd
The challenge I have is that the TV takes about 5-7 seconds for the picture to warm up and come on. As soon as it does, having HDMI Control on the receiver and TV causes the TV to tell the receiver to switch to the TV input. This then moves my receiver off of HDMI 2 (where it needs to be) and over to an AV input on the receiver which is mapped to ARC. However no sound is coming through ARC at that point since its just the STB playing. Yes later if I use Netflix or Vudu it works, but most times I'm just TV watching. This means after the power on sequence I have to manually switch the AVR back to HDMI 2. That's not acceptable so I've given up on ARC unfortunately. Maybe one day they'll be a fix or someone will discover a work around.,..
I do get what you mean. I have the same issue when I shut off the BD player. I'd like the AVR to switch to the STB automatically but it will switch to TV input instead. The STB has HDMI but otherwise there is no CEC compliance so I guess that's why the AVR never switches to the STB even though I pretty much always have it powered on. I do agree that it is annoying but it isn't a dealbreaker. I just switch inputs manually. Perhaps you can try switching off the TV Anynet+? I'm not at home to test out whether this affects the ARC feature.
Yes! This is exactly the step I was missing. I tried it and it works wonderfully. Thank you so much!!
I tried to get the Playstation Media Server (PMS) going because I like that it'll transcode (?) the audio on the fly if it needs to. But I couldn't get it configured. It had nothing to do with the Samsung. Rather, I couldn't get it to see my PS3 (or Samsung either). I installed PC Share Manager and it does the trick.
Question: Is there any way to get the Media Play function on the TV to remember PC Media Share as the default DLNA server? Every time I go into the menu (or maybe its after a power off/on, but still...) it defaults to my USB drive in the TV or Media Player on my PC networks. So I have to press the "A" key and navigate to select "PC Media Share" to find the media I want.
Thanks again!
Thanks again!
I don't recall experiencing any sort of memory or default on the choice of media player inputs. If I recall, even if I plug in a USB drive, I still have to select the drive from the list of sources to access the media player. Again, for me, I'm pretty tolerant of the need to use the remote. In fact, I quit using a USB once I installed PCMS. PCMS is the only media player I have installed.
