AVS › AVS Forum › Audio › Home Theater In A Box › clueless about what to get.
post #1 of 10
i just got a 40in samsung tv, and the speakers are crap. and was looking to get a htib.
my room is 12*12. i will mostly be using for tv speakers, music, movies, ps3. in that order of importance.
my budget if it does not come with a blue ray player is 350-400. 450-500 with blueray player.
also with this budget can i get a 5.1 built separately or would it be better to get htib.
post #2 of 10
Your small budget only allows for a HTIB
Something like the:
-Onkyo HT-S3300
-Yamaha YHT-393bl
The main difference is the Yamaha has a powered subwoofer not passive like the Onkyo has.
Onkyo has recently been recalled for service so I would wait a month until they fix their issue
post #3 of 10
post #4 of 10
iv thought about it, and iv decided id rather get quality right now and slowly build up. what do you guys recomend for a 2.1 not floorstanding i need to put the speakers on my desk or mount to the wall. for 350-400. that i would later be able to upgrade. right now i have sony bookshelf speakers that i would use for rear they are crap but at least would have me sound.
post #5 of 10
Its the same dilemma, you cant get two speakers, sub and receiver all for $350-$400.
The 5.1 Jamo system is $199 which is a very, very good deal for the money. You wont find two speakers and a sub for that price.
You can get two decent bookshelf speakers for $150 but a seperate sub will cost you another $150 minimum.
You'll have to search craigslist and ebay for used speakers if you want to keep within your budget.
post #6 of 10
the quality of the jamo 5.1 for 200 is going to be better than if i get a pair of bookshelf speakers for 200. the reason i want to go for quality for the front speakers and then in the future upgrade the rear.
post #7 of 10
sorry to jump off this topic but whats the difference between a powered and passive subwoofer and which is better
post #8 of 10
Powered subs have their own amps onboard. Passive subs need power from either the receiver or (less commonly) an external amp.
In practical terms, a powered sub is better, as it doesn't rely on (often smaller) receiver amps. Powered subs also tend to be built larger, more powerful, and better sounding. I'd only recommend a passive sub if your receiver only has a passive output for the LFE channel.
post #9 of 10
Why would you be interested in another bluray player when you have a ps3?
Ive seen some good reviews on the Sony ht-ss370. 3 hdmi in/1 hdmi out. Easy to setup. $350
post #10 of 10
You could go with some Polk Audio Monitors.
Monitor 30 Bookshelf
http://www.newegg.com/Product/Produc...82E16882290094
Monitor CS1 center
http://www.newegg.com/Product/Produc...82E16882290022
PSW 10 subwoofer
http://www.newegg.com/Product/Produc...82E16882290034
Then you're going to have to hunt for a deal on a HD audio equipped budget receiver if you want to be able to listen to HD audio from your PS3 Blu-Ray player. Check slickdeals.net.
  Back to Forum: Home Theater In A Box
