AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz SR5004 no video out HELP!!!
post #1 of 3
Hi all...
Recently I bought my home theater system which includes:
Marantz SR5004 + 5.1 Tangent Clarity
Asus EB1020 (used as Media center)
Projector Sanyo Z2 (2nd hand)
I have some problems when I connect the projector through the receiver. I am using HDMI connections from the PC to the receiver as well as from the receiver to the projector (HDMI->DVI convert in the projector-end).
- If I connect the projector directly to the PC (either Win7 or Ubuntu), I got video in the projector without any problem.
- I know that the video output of the Marantz is alive because I can see the "marantz" menu in the projected image.
- I have tried many resolutions in the PC (HD 720p and normal pc), and I have set the marantz to pass through the video signal, and converting it to something else, but nothing.... BLANK SCREEN...
Any idea?
Thank in advance for you help...
post #2 of 3
Originally Posted by mfsd View Post
Hi all...
Any idea?
Does your PJ display what signal type it is getting from the PC?
post #3 of 3
You will be limited with many avr's to strict known common HDTV resolutions and refresh rate, color, ect..ect...
I'd bank you have it set to something the AVR does not support.
