Originally Posted by rfogarasi
Just had the Whole Home DVR installed, The technician put in a bad SWM switch and left my Netgear wireless adapters hooked up to the DVR's claiming that I still need those for on demand (that is how I used to get it before the install). Doesn't this whole home thing do that anyways?
Right after he left the receivers stopped communicating and my in home network went down. I went to the store and bought a new router thinking that might be the problem and amazingly still didn't work. Disconnected all receivers from my home network and everything with my home network is fine however the receivers are still not talking to each other. Now I have to wait for someone to come back to get me a new SWM to make it work. THIS WAS A PAIN.... They need to get their crap together. Again, do I need the in house network for on-demand or is it all done through their equipment?
While you haven't given much information about what you have,
When the Connected Home networking is setup [correctly] all the receivers are networked through the coax, and there is another BB DECA that bridges the coax network to your home network, for internet access.
. It's a really old router with only wireless G so it was due for an upgrade anyway. Temporarily I'm using a cheap Belkin router (any router recommendations?), but with it in my network, the apps have started to work - sporadically. They seem to mostly be working on my HR-23 DVR, but only fleetingly on my HR21 where the CCK/BB DECA is actually connected. Typically I see a "services unavailable" message. Resetting to defaults, reconnecting to the internet/network, etc. don't seem to solve it. When I select "start network services" I get either the 301 error again or "services have successfully started, but connection test failed". Repeating that a couple of times I sometimes get they message that everything is working, but when trying to use the TV apps I still get the services unavailable message. I can go downstairs and pull up the apps on my HR23 however.
