Originally Posted by Vin
Okay, now for the bad news. First of all, let me fess up
....my two HR22s are networked via powerline adapters, the HR-21 in my basement has a direct ethernet connection. Up until now, there appeared to be no difference, I've been able to get On Demand on all 3, no problem.
Now, keeping in mind I spent very little time tinkering with this last night, what I'm seeing so far is that accessing the ethernet connected HR-21 in the basement from the powerline connected HR-22 in the kitchen works perfectly. The other way around, however, (accessing the powerline connected HR22 from the ethernet connected HR-21) results in lots of studdering.
Trying to access the powerline connected HR22 in the kitchen from the powerline connected HR22 in the living room didn't work at all....I received a message saying something like 'packets missing' or something to that affect. Resetting the DVRs did not seem to help.
This is as far as I got, I hope to get some time tonight to play some more. Anyway, from the limited troubleshooting I've done so far, I'm assuming the powerline adpaters are just not cutting it. Does that sound like a reasonable assumption or is there something else I need to do before moving on to Plan B, i.e, running Cat5e to the two DVRS in question?
....my two HR22s are networked via powerline adapters, the HR-21 in my basement has a direct ethernet connection. Up until now, there appeared to be no difference, I've been able to get On Demand on all 3, no problem.Now, keeping in mind I spent very little time tinkering with this last night, what I'm seeing so far is that accessing the ethernet connected HR-21 in the basement from the powerline connected HR-22 in the kitchen works perfectly. The other way around, however, (accessing the powerline connected HR22 from the ethernet connected HR-21) results in lots of studdering.
Okay, I've made some progress. When I first set up my powerline adapter in the kitchen for On Demand, I connected it to an extension cord (I know, this is a no-no but it was the most convenient way to do it at the time) and it seemed to work fine. Well, after removing the extension cord and plugging it directly into the wall outlet it began to function as well as my wired HR21 in the basement, i.e., viewing from either location played back perfectly, no studdering.
Now, onto the living room where until now, didn't function at all with the WHDVR service. This powerline adapter was not only plugged into an extension cord, it was plugged into a power strip...a BIG NO-NO
but it had also functioned fine for On Demand. Okay, so after connecting that one directly into the wall outlet it began to work but not perfectly....I was still getting studdering when accessing programs from the other two DVRs and the kitchen DVR (with the corrected powerline connection) also studdered when accessing the still troublesome living room DVR. Accessing the living room DVR from the wired DVR in the basement, however, now plays perfectly.So, the next thing I'll try is swapping the two powerline adapters and see if that makes a difference since the one that is now working in the kitchen is a Netgear and the one in the living room that has improved but is still unacceptable is a ZyXEL, (both are 85Mbps units). For the record, the adapter plugged into the router is also a ZyXEL, same model as the living room unit. What's unique about the ZyXEL is that it's not your typical wall-wart type of powerline adapter connection, it has an electrical cord instead (like a lamp) that just plugs into an outlet....not sure if this has anything to do with it. As I said, I'll swap them and see if the ZyXEL performs any better in the kitchen but more importantly will be whether or not the Netgear performs as well in the living room as it does in the kitchen...if it does I'll just get another one.
Thanks rad for bringing me up to speed on the WHDVR service.
