I have a Sony KDSR50XBR1 that started the infamous green tint, but it's very slight, and only when I have static image for a while, and it had only been creeping up in the last couple months. Before all this happened, I absolutely loved this TV.
Sony gave me credit towards a new LCD (which I took), and my plan was to run the "old" one until the bulb ran out. A few days ago the bulb went out (the green light blinks like 30 times green, then the red "lamp" light blinks "forever", and when I restart the TV, a buzzing noise is made).
I was thinking about just chucking the TV, but if I can fix it with a $100 bulb, I feel like it's worth keeping. A functioning, high-quality big screen for a $100-$150 is a bargain. My question is, will the "green tint" issue only get worse over time until it's unwatchable? Will the bulb replacement make the green tint issue "better"? It seems like the problem got worse right before the bulb went.
My fear is I buy a new bulb and I end up having to throw the TV away because A) the bulb is not the problem and B) the green tint gets so bad it's unwatchable.
I would love to have any feedback or input.
