Originally Posted by 68cam454
I have the exact same problem with my VSX-32 that I picked up on Saturday. It will connect fine but will loose the connection after 30-40 minutes. The only way I can get it to connect again is to power it off and back on. My PS3 is also connected to the same bridge and doesn't have a problem. I tried setting the IP,DNS and such manually and it does the same thing. I power cycled the router and bridge and the only way the connection comes back is by power cycling the receiver. I am going to bypass the wireless bridge and try going directly to the router tonight to see if that helps.....if not, it's back to the store for an exchange (this was also the suggestion from Pioneer support).
I hope I dont have to send it back, everything else works fine. I'm hoping it's something that can be fixed via firmware update. Have you been able to hook it up directly to your router yet? Im interesting to know if it works. Im looking for a cable long enough for mine to try out.
