Originally Posted by grpape
Thanks for all the help guys.
I tried everything possible. I did have the subs on "on" and still no recognition from the MCACC set up. I turned the gain up all the way, and still no recognition. I'm pretty sure it's doa.
When I play something in Dolby or other settings the screen (on the AVR face) has all the speakers and the sub with the lines (shows that there is a LFE being recognized by the AVR). All the other speakers are playing but nothing from the sub.
I'm gonna send it back to Amazon and do some more research and decide whether or not to stick with Pio or go Yammy. I probably will just get another 1120 unless I move up to the next level.
Derrick
Derrick
You are now the fourth person to report a broken sub pre-out (myself included). Mine failed two months after I bought it, but it was user error -- I moved the avr with the sub cable plugged in, and somehow broke whatever weak metal ring is on the inside of the pre-out.
The repair was simple -- they re-soldered the ring -- and mine has been working perfectly ever since.
That said, the pre-out for the sub does appear to be a weakpoint. I wouldn't call this a large trend, but everyone with this unit needs to be EXTRA careful when plugging the RCA in and out of the SW port.
You should just exchange it for another 1120. The next one will work just fine, I promise. Just be careful!
