AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer VSX-1120 TXH HDMI V1.4 Receiver Owners' Thread
Pioneer VSX-1120 TXH HDMI V1.4 Receiver Owners' Thread - Page 168
post #5011 of 5025
Am I the only one who thinks it's silly that after all these years they still can't release an android app that works with this receiver?
despite it launching with an ios app...
post #5012 of 5025
post #5013 of 5025
You can buy some other apps that work with this receiver for Android just fine.
I am using iControlAVA for my android device and it works well.
post #5014 of 5025
I am also frustrated they have never released an Android app. Even more frustrating is the lack of punch this receiver has provided. I recently brought my 1120 into a custom speaker shop and had them compare it to a 30 year old Yamaha amp they use to test their speakers, and at -3db, the 1120 sounded flat and about 1/2 the volume of the Yamaha which was only about 1/4 open. I even did a factory reset as I figured a setting was causing this issue. The source was a Maranz reference CD player connected to the CD input through reference RCA cables. With how great the reviews have been on this receiver, I still feel like I must be doing something wrong. Any suggestions, your help is greatly appreciated!
post #5015 of 5025
Does iControlAVA allow for NAS playback?
post #5016 of 5025
I assume you mean Network Attach Storage from NAS? I am not sure it does though I don't use any sources for music listening via network device other than the whats on TV. You can browse the internet radio channels via the app so I assume it would work the same way for the NAS as it does take you to sub menu.
The screen shot here shows what it looks like on an iPod device. The channels are displayed on the TV though and not on the phone.
post #5017 of 5025
Yes that is what I was referring to by NAS. I couldn't find the screenshot?
Also, I know you have long been a fan of the 1120, any suggestions to my above question with regards to lack of what seems to be full power?
post #5018 of 5025
The link didn't paste I guess you can look at it on the app on google play store. Its the last screen shot on the app page.
I assume you mean bass by punch? Hmm I had bass control issues on my Sub well initially (I was comparing it to a Denon 2808Ci that I upgraded from) I resolved this by changing the location and turning on the bass boost on the Sub and cross over. It sounds fine now. Are you using the calibration via mic setting? I always add some db in the rear speakers for cable sources and bass boost is known issues for all receivers from what I have read.
I have satellite speakers (KEF 3005) so they are not power hungry by any means. Though this receiver has enough power to push the 8 ohm receivers to levels before your ears call uncle. Can you expand on what the issue is? If its not the bass issue and you are playing just stereo sound you know you can go above the 0 db level. I also am pretty sure the 30 year old Yamaha is a stereo receiver how many speakers are you running on the 1120? Switch to the stereo mode to do an apples to apples comparison.
post #5019 of 5025
I meant overall loudness off the speakers, clarity and volume level. We were just testing it in a mono setup to one 8" 8ohm Solus Audio speaker. I had the input set to CD, Front Right speaker connection. I do believe the display said "stereo", but I did not change any settings. I even took it to +12 and while it got louder, yet still not as loud as the Yamaha, the clarity on the Pioneer suffered. At +12 I am worried the amp will overheat in no time. I just know I must be doing something wrong, I truly believe it is a great amp but just disappointed at the moment.
post #5020 of 5025
So you haven't ran the calibration with the included mic? I would run the auto calib and try again. I doubt you can strain the receiver with just two speakers hooked up. I am by no means an expert on speakers so cam't comment on the set you described. As for the Yamaha outperforming the Pio I am not surprised as its an old AVR and stereo one at that. There is a loudness button somewhere on the remote as well if I recall (I use harmony and don't listen to music much so have never used it) try fiddling with that a bit and see what happens. To summarize
a) run auto calib with the mic. (see what you speakers are set as Large or small if you have sub they should be set to small)
b) try boosting the audio with loudness
c) if that doesn't work try manually pushing the db on on left and right.
This is a decent AVR and for the price I got it was hard to beat. If you don't have an option to return then you can always go the separates route I suppose.
Good Luck
post #5021 of 5025
Hope some helpful soul reads this. Please give me, or provide a link on how to set up my SACD analog IC's out to this 1120 receiver. I want SACD MULTICHANNEL. I do not want PCM conversion. What am I not understanding? Does this unit not have sacd pass through? Do I need some kind of switch for my subwoofer to playback hdmi movies. I have tried several times since owning this receiver, and am not "getting it".
post #5022 of 5025
Does this receiver have multichannel analog inputs? It doesn't look like it from the specifications.
post #5023 of 5025
No, it does not, and I could kick myself two years ago, for not noticing this!
I have been pm'ing with an AVS member about using the coax digital or toslink out of my Pioneer DV-563A player, and he thinks I should get MC. But neither do I, nor the people at SACD.net think this will achieve dsd two channel, or MC channel output. Perhaps a newer player like an Oppo, or Denon. But would the 1120 convert the dsd to pcm? Right now, I am mad at myself for not getting it RIGHT two years ago, and for putting so much effort into a dead format. What inspired me was the industry's newest half hearted attempt with using these two formats and putting them oh high fidelity pure audio on blu-ray. Some of these sound fantastic! But they are charging too much, poor distribution, and using poor sources with little or no recording information will surely kill this little niche market as well. I'm going to make a sandwich, have a cup of tea, and dig up my old Technics receiver that HAS the analog mc inputs. I guess I will just have to get a switcher for ALL my speaker runs to do this. Adding to all the stereo crap in my small living room. Sign me, one very unhappy music man right now, and thanks for the posting.
post #5024 of 5025
I need some assistance getting internet radio stations through my 1120. My computer is connected (wirelessly) to the receiver, so no problem there. I can get an internet station to play on my computer, so I then copy the station's URL into the Internet Radio Setting Page and click on Update, but I get connection NG. I have some old stations programmed into the receiver, and when I click on them, they work. So I know the issue is finding URLs that work with the receiver.
Why do certain URL's that work on my computer fail to work with the receiver? Do I need to alter the URL somehow to make it work with the receiver? I"ve noticed that many of the stations that work on the receiver end in .pls. The stations that I want to add do not.
Maybe an easier question is whether any of you know the urls of some good classic rock stations that you know work with the receiver. I used to listen to Absolute Classic Rock UK, but they stopped streaming to the US.
post #5025 of 5025
I've been searching for an answer on this one, but can't seem to find it. What I want to do is hook up a chromecast to one of the HDMI inputs and output just audio to Zone 2 which I have wired to outside speakers. I tried using the Video and TV/SAT inputs, setting the HDMI input to input 3 which is where I plugged in the chromecast and have not been able to get any sound.
My old solution for having the independant audio was to use RCA cables to my phone and play from that, but I'd really rather use the chromecast as that would allow me to control the music more easily from my phone. Unless i'm missing something, my only option seems to get an HDMI and analog converter and use the input I know is working. Any ideas?
