Originally Posted by mark haflich
Few more comments on the Mits. It holds its own against my other projectors and the JVCs. Let it be said, everything is good and each projector has pros and cons relative to the others. And remember, I don't value on off as much as some others. I don't use DI's. The stuff I mostly watch doesn't benefit from any DI, good poor or average so I leave them off.
The Mits has bright corners visable under a 0 IRE full screen size window, However, in real viewing the bright corners are unnoticeable. If I didn't tests for this, I would not know that it had bright corners. .
I too don't like using DI's and don't care if it doesn't perform that well on the HC9000, I would rather keep it turned off, the blacks and shadow detail are great without it.
As for the bright corners I never even noticed it until one or two on here mentioned it, you don't notice it when showing a movie and isn't that what its all about, more watching film that running every test under the sun?
Im sure some on proj threads never watch a film
Happy B-Day and have fun!
