AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › NEW MITSUBISHI HC 9000 : FULL HD, 3D and..... Lcos panels
NEW MITSUBISHI HC 9000 : FULL HD, 3D and..... Lcos panels - Page 18
post #511 of 832
i got a 9000d several weeks ago and it is still unopened. does anyone know at what serial # does the advance (cms fixed) begin or how to tell if its the advance units?
considering switching it out for the advance unit if its the older version.
TIA.
post #512 of 832
TIA.
you might want to read a few posts back, Mark pretty much confirmed with Mitsubishi that the CMS has not been fixed even in the advanced version, it's only a power supply update.
post #513 of 832
Hopefully, we will get this clarified at Cedia. As i stated before most at Mits don't even know what a CMS is or whether it is working in their unit. It partially works, one can correct luminosity or luminence with it, but that's it. Second level projector customer support acknowledged after researching it higher up, that the CMS does not fully work and their is no fix yet. I asked if the Advanced designation included a fix and they said no, it just improved the power supply. I really don't know how accurate the info given me vs what some posters reported they have been told in Canada that the Advanced designation indicates a fix.
post #514 of 832
Hello together,
there seems to be some confusion about the new HC9000 A:
a) It is NOT released yet
b) It DOES HAVE an improved CMS
c) It does have an FI for 3D
d) An afterwards update of HC9000 to HC9000A is possible, but probably at additional (very moderate) costs.
Hope this helps...
Ekki
post #515 of 832
Speaking as a consumer, if an advertised feature doesn't work (as opposed to working awkwardly), I believe a manufacturer has an obligation to fix it for free. Because the A will have improvements in other areas, charging a modest fee for the upgrades to the PS and for FI in 3D, is certainly acceptable and commendable.
post #516 of 832
My Info Came straight from Mits Canada Upper Management
post #517 of 832
I would go with Cine4home's info here. I understand you want it to be as you were told but my gut tells me you were not given the correct info. I am not saying you were deliberately given the wrong info. Most in large scale consumer companies, rather than just a projector company, really don't know. Someone who doesn't know or didn't understand their question or was asked the wrong question, gives an answer, it gets repeated, and some take it as gospel. If you really want to knowfor sure, get someone with a probe and pattern generator come over and verify whether the CMS is fully functioning. I would give you 10 to one, it won't be but of course you copuld be right.
post #518 of 832
I would go with Cine4home's info here. .
We got that info directly from the Mitsubishi technicians at the IFA this week. And they had the new HC9000A there in the demo room.
Ekki
post #519 of 832
What the hell do they know compared to mid level management?
post #520 of 832
US press release
MITSUBISHI ELECTRIC VISUAL SOLUTIONS’ HC9000D 3D FRONT PROJECTOR FEATURES ANAMORPHIC SUPPORT, REDUCED PRICE
For more info visit: http://mitsubishi-presentations.com
Mitsubishi has reduced the price of its successful flagship Diamond HC9000D front projector to $5995. The projector is packed with features that create crisp, vivid, engaging 3D images that can be displayed on 100-inch screens.
Submitted to HomeToys.com on: 09/06/2011, 9:43 pm
Mitsubishi Electric Visual Solutions’ HC9000D 3D Front Projector Features Anamorphic Support, Reduced Price
IRVINE, Calif., September 7, 2011 - Mitsubishi Electric Visual Solutions America, Inc. has reduced the price of its successful flagship Diamond HC9000D front projector to $5995, and will be showcasing it along with its line of large-screen visual displays at the CEDIA Home Theater Show in Indianapolis, September 7-10, 2011 in Booth #5537. Mitsubishi Electric’s new Diamond HC9000D 3D projector is packed with features that create crisp, vivid, engaging 3D images that can be displayed on 100-inch screens, creating a true theater experience.
The HC9000D is also the only 3D projector in its price range that supports anamorphic modes, so viewing original widescreen 2.35:1 aspect ratio films is easy and cost effective. With support for Anamorphic Lens Modes 1 and 2, users enjoy the optimum home theater viewing experience with every inch of the screen filled with the movie, instead of a letterboxed format.
“Our customers get a huge bang for their 3D home theater buck with our HC9000D front projector,” said Wayne Kozuki, product manager, Mitsubishi Electric Visual Solutions America, Inc. “Whether you’re watching 2D or 3D, images literally appear to jump off the screen with realistic, true-to-life details.”
The projector also boasts the latest frame rate conversion technology: motion vector analysis is applied to each movie frame for highly accurate alignment using the preceding and subsequent frames. This compensation function creates the optimal number of frames for the content, reducing distortion in all directions: vertically, laterally and diagonally. Fast movie sequences are smooth and clear.
“Our 3D frame rate conversion technology literally can add frames to a movie to create an ultra smooth and judder free viewing experience,” said Kozuki.
Powered by an SXRD™ cutting-edge reflective liquid-crystal optical engine, Mitsubishi adds its own algorithms and processing technologies to create high-brightness, high-contrast (up to 150,000:1) images that are smooth and true to the original content.
A key element in projector performance is the lens, and Mitsubishi has incorporated extra-low dispersion glass into its six-piece, 17-cluster structure for higher functionality that minimizes chromatic aberration. The result is colors and details that are impeccably clear.
With its auto-iris function, Mitsubishi’s Diamond HC9000D 3D home theater projector automatically sets the optimal aperture according to each scene, and its 120Hz refresh rate produces ultra-smooth transitions and amazing life-like images. An independent color management function allows adjustment to color characteristics such as hue, intensity and brightness individually (red, green, cyan, magenta and yellow), without affecting the other colors.
With a wide range of powered lens shift (100 percent vertical and 45 percent horizontal), this new Mitsubishi Diamond HC9000D 3D projector is easy to install, even in a complicated room configuration. In some cases, there may not be a need to turn the projector upside down in a ceiling mount, and its 1.8x powered-zoom range also gives installers additional installation flexibility.
At only 23dBa, this Diamond HC9000D 3D projector is extremely quiet, so viewers can easily hear the movie—even in whisper-soft scenes—instead of an annoying projector hum. Two HDMI™ version 1.4 inputs support 3D signals, as well as provide easy set-up options for multiple video inputs, and its RS232 support offers plug-and-play connectivity with third-party remote operations.
Mitsubishi’s new Diamond HC9000D 3D projector also offers low cost of ownership with an estimated 4000-hour lamp life* in low conservation mode. It has a convenient and simple rear-access lamp design for easy lamp exchanges and a one-year limited warranty on the lamp, one of the best lamp warranties in the industry.
The projector is currently available though authorized Mitsubishi dealers and comes with Mitsubishi’s two-year limited warranty on parts and labor plus a one-year limited warranty on the lamp.
“Mitsubishi Electric is known for reliable, super large screen display technology, and now we’re building a great reputation for 3D home theater display products,” said James Chan, vice president, marketing, Mitsubishi Electric Visual Solutions America, Inc. “We continue to bring the best in front and rear projection using display technology to our home theater partners.”
About Mitsubishi Electric Visual Solutions America, Inc.
Headquartered in Irvine, Calif., Mitsubishi Electric Visual Solutions America, Inc. is a US subsidiary of Mitsubishi Electric Corporation of Tokyo, Japan. Mitsubishi Electric Visual Solutions America manufactures and markets a complete line of display products including projectors, data wall display systems, LCD digital signage monitors and players, large-screen 3D DLP® televisions and the world’s first laser TV, LaserVue®. Other products include industrial printers, photo kiosks and digital photo printers, time lapse security recorders and DVRs.
For additional information about Mitsubishi Electric Visual Solutions America, visit http://www.mevsa.com. You may also connect with Mitsubishi on Facebook (http://www.facebook.com/MitsubishiDisplays) and Twitter (http://twitter.com/MitsuDisplays)
*For an explanation of how this estimate was calculated, visit http://www.mitsubishi-presentations....lator_TCO.html. This estimate does not extend or otherwise modify the warranty for the lamp.
HDMI is a trademark of HDMI Licensing, LLC; DLP is a registered trademark of Texas Instruments. Other names may be trademarks of their respective owners.
post #521 of 832
Hello guys,
Anyone found extra glasses for children that are compatible with the HC 9000 ?
I've browsed around, but I'm not sure what exactly to look for. It should not be DLP link and and it's LCD active, but most of what I found is RF/Bluetooth synced and this Mitsubishi is IR, so I'm really lost...
Appreciate any help.
Mauricio
post #522 of 832
The HC9000D now shipping has the fixes needed to several things thast needed fxing such as the CMS. I don't know the serial number where the fixes are now included. But Mits said at the show that the fixes would be performed free for early adopters and that includes Mits picking up the tab for round trip shipping to the service depot in California. The unit can not be fixed or updated in the field. In a few weeks Mits will announce the procedure for getting an RMA etc. We will post it.
Buy the way. The quoted Mits announcement above I think has an error, it omits blue as a color that the CMS can adjust. It lists the other two primaries and the three secondaries.
Also. The biggest news. Just kidding about it being big news and it really doesn't mean anything but the usual JVC ad is missing from the latest Wide Screen Review issue and it has been replaced by an ad for the Mits HC9000D.
Seriously, this projector is very good and is fully competitive with the other stuff out there at the $7 to $8K MSRP price point, and now its only $6K MSRP. At the new street, one should not overlook this projector in favor of more well known brands.
post #523 of 832
Great news Mark! Can't wait to hear from Mitsubishi about the process. Its a little disappointing I will have to send my unit back to the mother ship for the update, but its great when a company stands behind their product.
I agree this is a great unit and with the lower price point people should entertain it as an option.
post #524 of 832
This projector looked good at the show, but Mit's handicapped it by only showing it in a booth. The back wall was just a curtain with a 3' wide opening for walking in and out. Since the trade show floor was so bright a ton of light entered the room through this opening, but even with this light you could see that this projector threw a nice contrasty image with good color.
post #525 of 832
I had our demo in my HT for about a month. I know how good it is.
post #526 of 832
Did anyone do a shootout between the Mits 9000 and the Sony VW90? I'm considering the VW95 and since its 2D performance should be very similar to the VW90, that would help me know whether I should also consider the Mits 9000 as well (assuming it had some advantages over the Sony 90).
post #527 of 832
Good question, I would like to know too...
post #528 of 832
I don't know what it is like compared to the vw90 (which I would also think to be very similar), but I saw the non-advanced model in action yesterday against the HW30 which is not really a fair comparison due to the different SXRD panels used, but it easily beats it in 2D.
The biggest downside for this PJ is the very dim 3D. Compared to the Sony it was almost literally night and day. The Sony was substantially brighter, but as a result did also still suffer from ghosting as far as I'm concerned (even though most are saying the HW30 is excellent on ghosting). Ghosting was not apparent on the HC9000 (most likely due to its dull, dark, lifeless picture) but honestly, even though I absolutely hate crosstalk, I would rather watch a 3D movie on the HW30 because of the HC9000's dimness.
What would make this HC9000 a real winner in my book, is if they get rid of the 3D alltogether and sell it at the HW30's price point. I'm aware the price is already substantially reduced for the HC9000D, but that just makes me feel that you still pay the extra compared to the HW30 for the 3D while in fact a lot of people would not find use for it.
Unless there is a way to make this PJ brighter in 3D with different glasses?
If so, I would love to hear about it!
post #529 of 832
Was it brighter in 3d only? how did they compare in brightness in 2d?
post #530 of 832
Will say this regarding 2d brightness
Coming from an Epson Pro 9700ub I always had to have the lamp on High never was able to watch in full ambient light on Echo..
with this Mits 9000 i never watch the unit on High Lamp mode
Even in full ambient light its on Normal Lamp mode
Dont need it on high
2d sports in ambient light Rocks on when Paired with an SI Black diamond Screen,.... And i am running it with a .8 gain
and if i had 1.4 gain it would have even more contrast in ambient light
post #531 of 832
Definitely much brighter in 3D, but I'm judging this with glasses on and so am only stating that the glasses for the Mits were much darker than the Sony. While I'm sure the extra brightness of the Sony is in part achieved through their timed lamp boost technology, another part of it is the glasses.
Is it because of the fact that they have a different filter or is it that the higher refresh lets through more light, I don't know (not completely up to speed on all the tech behind it) but the difference with glasses on was very noticeable.
I didn't actually compare the light output of both PJ's in 3D without the glasses on so don't know if there was any difference there...
Light output in 2D as far as I'm concerned was pretty much the same. Measurements might conceivably yield differences between the two, but on a purely subjective level, they appeared pretty close to me.
What I failed to mention was that the screen was a pretty standard 1.0 gain acoustically transparent screen. I guess the Mits' brightness for 3D could be raised by changing the screen to something with more gain, but I have no way to compare and am unsure to what extent this could solve the 3D dimness. Conversely, going for higher gain might then cause issues in 2D?
post #532 of 832
The tint has little to do with the brightness one gets. Its mostly in how long the shutter on each eye is open for.
I hasve had both machines and I found the brightness on the Mits in 3D to be quite adequate. Not as bright as the Sony though.
The Mits is a more expensive projector. It shows it in size and mass and its lens is in a whole other league. Subjectively, I rate it as the best lens in the $6K to $8K price class.
The Sony is much lower in price class. It is a very fine projector none the less but throw some more money at it, and it would be even better and noticeably so.
post #533 of 832
Standard 1.0 gain vs a BD 1.4 G3 Screen would make a huge difference in boosting the contrast of the Mits
Higher gain atleast in the Bd will give you not as good black levels in ambient light
when i mean higher gain i am talking 2.7gain vs 1.4
again
the mits with the 1.4 gain is a Show stopper in ambient light
post #534 of 832
In 3D mode, the MITs is switched to high lamp.
post #535 of 832
Sounds like it's the Sony 95 that should be compared with the Mits 9000.
post #536 of 832
Seems bright enough for 3D on an HP screen getting 2.2 gain at 110" to maybe even up to 120", unless Art's numbers were off:
Using Art's 700 Lumens Best Mode number from PJ Reviews:
110" Screen at Closest Throw at 2.2 Gain
<<Calculations for a New Lamp>>
110" Screen (Lamp Low Best Mode)= 35.1fL
110" Screen (Lamp HIGH Best Mode)= 46.8fL
110" Screen (Semi-Accurate NON-Best Mode)= 56.8fL
110" Screen (Absolute Brightest Mode)= 66.9fL
120" Screen at Closest Throw at 2.2 Gain
120" Screen (Lamp Low Best Mode)= 29.5fL
120" Screen (Lamp HIGH Best Mode)= 39.3fL
120" Screen (Semi-Accurate NON-Best Mode)= 47.8fL
120" Screen (Absolute Brightest Mode)= 56.2fL
Note:
The Sony hw30 appears to be about 50-100 lumens brighter overall, not a huge difference, so like others said it's probably partly the design of the glasses.
post #537 of 832
Couple of ambient light shots
that i posted in an album on facebook
This is a good example to show how bright the Mits Is
again i am using a .8 gain screen
Was taken with my Insignia Digital camera so its not a pro shot
post #538 of 832
With the recent price cut for the HC9000D, the Mits is no longer that much more expensive. Over here, it ends up being 800€ more than the Sony, still nothing to sneeze at but it makes it a relatively affordable jump to the better SXRD panels compared to the vw90 or vw95. The latter being 1500€ more expensive.
What screen were you using Mark? In my opinion, i.e. very personal impression, it was nowhere near bright enough to be enjoyable on a 1.0 gain screen.
again
I'm not concerned about ambient light as much. But does a 1.4 gain screen not run into any other problems? Coming from CRT, I'm not really up to speed on this for the current crop of digi's. Hotspotting an issue or something? Reduced contrast? Anything else?
I've only vaguely heard about the Blackdiamond screen but in the demo the guy from the store very briefly held up a small segment of BD screen (no idea of the gain however) in front of the main screen. Not really fair to make any estimation based on the very short amount of time, but it looked at least as good as the 1.0 gain, probably even better. I guess I'll have to do some more research on it
post #539 of 832
Note:
Tx much for making those measurements! If I convert to lumens, I get the same for both screen sizes (which of course SHOULD be true): in best mode, this is ~ 575 lumens in low lamp, and 768 in high lamp.
post #540 of 832
These shots below where taken in Normal Lamp Mode....
