Greetings,
I have a Panasonic 42PX80 TV and noticed something I'm hoping others can confirm and suggest fix, if possible: I have a PS3 (or any media device) and normally I set it to output audio via optical to receiver and hdmi video to the tv. I decided to try straight HDMI to tv and use the 42PX80's digital audio output to the receiver. After confirming all settings were correct in PS3 I switched it and found that the audio is truncated down to 2.1 rather than 5.1 or so surround. I tried fiddling with audio settings in TV but nothing helped so I put things back the to "normal" under the assumption the TV can not correctly pass thru the audio data stream to receiver. Is this a hardware limitation or perhaps there is a firmware fix for the TV? Perhaps there is an issue with the HDMI cable? I know the receiver is fine as 5.1/DTS works fine when audio is direct to the receiver and not passed thru TV. The end goal here is to utilize the three HDMI inputs on the TV and use the optical connection from it pass the surround to the receiver. My receiver is a Harman-Kardon/AVR-245
I hope some one has some insight to share because I'm at a loss.
NOTE: Normally I would input the devices via hdmi to the A/V receiver and output video to tv as a monitor. However, the H/K 245 has a known issue in transmitting video via hdmi but that shouldn't have anything to do with my passing thru digital audio from TV to the receivers digital audio input (tos).
